Will 295's fit?
Old May 6, 2005 | 02:26 AM
slowtraffickeepright's Avatar
Default Will 295's fit?
I just replaced my stock 18 x 9.5 rear wheels with repro Z06 18 x 10.5's. Though I still have my stock size 275's on the rear, I intend to replace them with 295's. The 275's are now too narrow for the rims.
My question is that with my fender now about 2 inches above the tire, it seems that the wider tires might rub over up/down travel. My friends Z06 has this setup stock, but his car sits alot higher. I was surprised to see this tight situation, I thought that this was a pretty mild change.
What have your experiences been with this? Please share.
Thanks.
Old May 6, 2005 | 06:48 AM
WKMCD's Avatar
WKMCD
Mines lowered with 18's all around. 265x35 front and 295x35 rear. No problem.
Old May 6, 2005 | 09:43 AM
What kind of wheels do you have? Are they stock wheels with stock backspacing?
Old May 6, 2005 | 01:21 PM
slik_z06's Avatar
slik_z06
No problems with my car so far: 19's all the way around.... 305/30 rears. I think 295/30 for the front...
Old May 6, 2005 | 08:28 PM
Lancer033's Avatar
Lancer033
295 is the stock size for the Z06, 305s will work with no problem and you could squeeze a 315 on that wheel if you wanted to. This is all assuming that the wheel has the stock backspacing. Since they are repos, I'm sure they do.
I've got 295/35-18s on my car right now and there is plenty of room in there
Old May 6, 2005 | 10:17 PM
army2000's Avatar
army2000
St. Jude Donor '11
I'm running 18x10.5 on the rears with 295's. No problemo
Old May 6, 2005 | 10:44 PM
I appreciate your replies, guys. My concern is if the wider tires will travel up into the wheel well without rubbing. I don't want to raise the car at all. It seems that stock, the wheel well is much higher.
Old May 9, 2005 | 04:10 PM
FKING1's Avatar
FKING1
Same setup here. Lowered nearly 2". No rubs or probs.
Fred
Old May 9, 2005 | 04:17 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
No worries..you'll be fine..I have had two different setups similar...and neither rubbed..lowered 1 inch
Old May 9, 2005 | 07:06 PM
jim2527's Avatar
jim2527
Do you still have the stock 17's out front? IRRC 295/35-18's are a tick shorter in diameter. If they are they throw off your TC/AcH. You must maintain a .5 inch diamter difference!!!!!!
Old May 9, 2005 | 08:24 PM
69's Avatar
69
Cruise-In VI Veteran
This is the combo I have.
Old May 10, 2005 | 01:04 AM
Thanks, I'd say you guys about covered it.
295's it is.
Old May 10, 2005 | 12:16 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
295's it is.
You may want to give the 305s another look as they put more rubber on the ground (in Pirelli P-Zeros the 305 is one inch wider than the 295s and the tire height is the same).
Joe
Old May 10, 2005 | 02:16 PM
flynbya2's Avatar
flynbya2
Actually Joe,
I have been told that the measurement(305 or 295 whatever) is from sidewall to sidewall...and does not reflect the footprint. In this case,the footprint is relatively the same.
I am not trying to bust anyone's chops here....just thought it may be of interest...as I thought the same as you were,untill ccw set me straight!
Old May 10, 2005 | 03:56 PM
C54FUN's Avatar
C54FUN
Originally Posted by flynbya2
Actually Joe,
I appreciate your clarification. What's interesting here is the folks that sold me my HREs and tires had me wait several weeks longer to get the 305s because of the alleged "one inch." I wouldn't doubt what you say and certainly not CCW as it would now appear I waited longer to get my stuff for no valid reason...so much for the expert advise I received.
Joe
Old May 10, 2005 | 04:20 PM
flynbya2's Avatar
flynbya2
FWIW..ccw had both types of tires in stock..and I originally wanted the "extra" inch as well.When John( if I remember right)told me the above and I think he said that he thought the pilot sports actually had a greater imprint( if I remember correctly..or it could have been he said they "appeared" larger...I honestly don't remember the exact phrase.)
But, that is the reason I went with pilot sports,plus I previously had them and was well aware of their ride quality
Both are good choices,I think anyway. Point is...not a big difference!
Old May 10, 2005 | 11:49 PM
curtbriggs's Avatar
curtbriggs
Default 315's
I have Michelin PS2 315/30 X18" on the rear of my 99 Coupe. No problems with stock height.
Old May 11, 2005 | 09:05 AM
jim2527's Avatar
jim2527
Something to consider is the sidewall design. I have Toyo T1-S in the 295/35-18. They have a rounded shoulder that looks kind of wierd. A tire with a squarer shoulder looks better in my opinion and because it has a square shoulder it may give a wider tread.
I just checked some specs to give you an idea of how this works. The BFG has a tread width of 9.8 inches and the Bridgestone has a tread width of 11.5 inches. Same size tires!!!!
To Will 295's fit?
