need help with keyless remote
Old May 6, 2005 | 11:52 AM
Rob P's Avatar
Rob P
Default need help with keyless remote
I have 99 coupe with the passive option on the remote. I don't understand the remote, if I don't use the car for 1 or 2 days, I have to reset the remote. Also, the car keeps locking itself after I already pressed the lock button.
I have replaced the battery on the remote.
Does anyone know what is going on? What is the passive option on the remote?
Old May 6, 2005 | 12:13 PM
Kenny94945's Avatar
Kenny94945
I currently have the same issue....do not use car for X period and I need to re-sync the fob.
Do a search for my story.
Dealership helped, but did not cure by placing BCM, after replacing fobs and RTF antenna.
Also a co-member Bill I believe has a great how to about cleaning the grounds for the passive system.
You can also check the wiring for damage at the passenger footwell fuse box area.
Old May 6, 2005 | 01:08 PM
Rob P's Avatar
Rob P
thanks.
I haven't tried programming the fob in the ignition as you wrote. I will try that today and see what happens.
I still do not know what the passive function does
Old May 6, 2005 | 01:23 PM
jawsski's Avatar
jawsski
The passive function enabled lets you walk away from the car and it will lock itself after you walk bout 15-25 feet. And will unlock the car as you approach it within 15-25 feet.
I thought this was a neat option until I discovered that where i hang my keys is just inside my front door 20 feet from the car.....the locks cycled quite a bit....perhaps this is your problem.......lock..unlock.......lock..u nlock.......lock..unlock.......lock..unl ock.......
Old May 6, 2005 | 02:55 PM
vizette's Avatar
vizette
Default FOB issue
Not sure about the passive - but when my fob went bad, i had similar issues. I would have to sync it, and it would only hold for a short time, and when it did, it still didn't work right. When i hit lock or unlock, it would lock or unlock both sides twice.
-Rich
Old May 6, 2005 | 04:34 PM
lost's Avatar
lost
The passive feature sucks, which is why it was done away with on later models.I carry my keys in my pocket, have have the passive switch accidently go to the on position and have had the constant lights on, lights off, lock, unlock as I walk around my home, drain my battery on at least five occasions.If your battery gets to a low voltage condition the fob will lose sync , requiring re-syncing.
To need help with keyless remote
