Burned the clutch?
Old May 6, 2005 | 07:49 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Burned the clutch?
A few nights ago I did a hard launch from a stop - just like 100 times before. This time, though, something seemed to slip. I thought it might just be the tires, but then came the stink and I assumed it was probably the clutch.
Since that time, I cannot get the clutch to slip by romping on the throttle, yet I am still smelling a burning smell. Then I received a "Service Traction Control System" from the DIC <No, I havn't pulled the codes from it yet - I will do so tonight>
I have 45K miles on the original clutch - other than a few track days and the occasional burnout, I am pretty easy on the clutch.
Do you think it's the clutch? Or can something else in the traction control system burn?
Thanks,
Old May 6, 2005 | 10:10 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
Old May 6, 2005 | 11:03 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
There is a pretty good way to tell if a clutch is going out.
Stomping it in first gear will not do it.
Go find yourself a nice piece of interstate or road with a pretty steep hill, put the car is a high gear, 5th or 6th and when you get to the hill stand on it. It will put a high load on the car at low RPM, if the clutch is band, it will slip then.
I had a C4 that I fried the clutch at the track on, drove it home from NC back to TN.. just have to downshift on the hills as it would start slipping when I was climing hills in 5th.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old May 7, 2005 | 08:42 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
im not sure 100 hard lauches and days at the track, is easy on the clutch, but I agree with the 5-6 gear going up the hill theory.
Im hopping my clutch goes sooner than later to I can get a new set of heads and clutch
Old May 7, 2005 | 11:48 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
It takes a while for the stench to leave. Trust me....I know
Old May 9, 2005 | 02:48 PM
SDVette's Avatar
SDVette
I should clarify... A "hard launch" for me does not involve slipping the clutch.. And the track days were on a road coarse (not dragstrip); hard on the tires and brakes for sure, but not too hard on the clutch.
Thanks all for the input. Still haven't pulled the codes (moved this weekend!)
To Burned the clutch?
