coolant drain ???
Old May 7, 2005 | 11:47 AM
white top's Avatar
white top
Default coolant drain ???
Recently tried to drain & refill the coolant when I opened the drain on the radiator only got out one gal. am I missing something or is there something else I need to do.....Help!!!
Old May 7, 2005 | 11:55 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Drain and fill procedure:
Make sure engine is cool, remove radiator fill cap
Open radiator drain ****
Allow to drain completely
Close drain ****.
Fill system thru surge tank opening
********Fill half the system with 100% Dex Cool
********Add clean water till it reaches the base of the neck.
Start engine and idle for 1 minute
Replace surge tank cap
Cycle engine RPM from idle to 3000 in 30 second intervals until coolant temp reaches 99 degrees
Shut off engine
Remove surge tank cap
Start engine
Idle for 1 minute and fill surge tank to ½ inch ABOVE Full Cold mark on tank
Install surge cap
Cycle engine again idle to 3000 RPM in 30 second intervals until temp reaches 99 degrees
Shut off engine
Top off coolant as necessary ½ inch ABOVE FULL COLD mark on tank
Old May 7, 2005 | 12:09 PM
white top's Avatar
white top
pewter99 did all of that but only one gal. drains out is that normal?
Old May 7, 2005 | 12:19 PM
pewter99's Avatar
pewter99
I don't recall but I don't think it holds much more than that if that much...don't have my manual in front of me.....I think when I refilled mine it didn't take the whole gallon of DEXCOOL premix
Old May 7, 2005 | 12:58 PM
7Deuce's Avatar
7Deuce
I just drained mine recently. I think the entire cooling system holds 12 qts of coolant. When I drained mine I got out about 10 quarts (a little over 2 gallons). I did have my front wheels up on ramps and to get the last couple of quarts out I jacked up the rear end so it was a little higher than the front end but it drained at least 7-8 qts before I had to do this. You should be getting out a lot more than just 1 gallon. Did you open the fill cap when you drained it?
Old May 7, 2005 | 01:10 PM
7Deuce's Avatar
7Deuce
white top -
check out this thread about coolant change.
http://forums.corvetteforum.com/show...nge&forum_id=1
About 3/4 through the thread there is a post by jimcork1 and he says he got out about 11qts. If you're only getting out 4 qts I don't think that is normal.
Old May 7, 2005 | 01:38 PM
Pumba's Avatar
Pumba
Jerry,
In addition to the radiator drain ****, there are drain plugs on each side of the block that must be removed to get the coolant out of the engine block. These plugs are extremely difficult to get to without removing the exhaust manifolds and starter. In addition, once you have the radiator and block drained, you should take an air hose an blow the coolant out of the heater core.
Good luck.
Old May 7, 2005 | 01:46 PM
7Deuce's Avatar
7Deuce
Originally Posted by Pumba
Jerry,
Good luck.
Just to clarify...when I drained mine I got 10qts out of the radiator/coolant reservior. I did NOT drain the block. The only drain plug I opened was on the lower passenger side corner of the radiator.
Old May 7, 2005 | 01:52 PM
pewter99's Avatar
pewter99
if you do the flush and fill you should get what you need..I think we are all on a different page here
Radiator only probably 4 qts..entire system definetly more
Old May 7, 2005 | 05:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do the power flush, much better and well worth the money, IMHO.
Old May 8, 2005 | 03:59 PM
c3andc5's Avatar
c3andc5
I replaced my coolant last week and I was able to drain 8 qts from the petcock at the bottom of the radiator. Since I had the car up on ramps I had to use a pump to get about 1 pint that settled in the rear of the surge tank. the Dex-Cool was in good shape so I didn't need to flush. Btw, if you do flush, don't use anything other then water. Flush products can have a bad reaction with Dex-Cool and cause major problems with gaskets, etc.
Old May 8, 2005 | 05:03 PM
Oldvetter's Avatar
Oldvetter
I got about 11 quarts from mine. It was very clean, shop manual says if it is clean there is no reason to flush system. I did not flush the system. Changed mine at 5 years, but only about 60,000 miles.
Be careful when opening drain valve, it only turns 90 degrees and then pops out. If you turn further you will break it (experience talking). New ones are under $5.00.
To coolant drain ???
