sway bar end links
Old May 8, 2005 | 02:43 AM
caster5303's Avatar
caster5303
Default sway bar end links
How difficult is it to change out the sway bar end links? Thinking about replacing the factory cheapos with better aftermarket ones.
Old May 8, 2005 | 08:00 AM
lar66BB's Avatar
lar66BB
Default end links
Not very difficult, the bottom bolt tends to spin when you try to remove
the nut. You just have to wedge a pry bar under and put pressure on it
so it can't spin.
Old May 8, 2005 | 11:44 AM
csexton's Avatar
csexton
Good info on LS1Howto.com
Old May 9, 2005 | 08:55 PM
jimcork1's Avatar
jimcork1
Use a 40 Tork in the end of the ball stud and a metric box end on the nut,, It will come right out. Been there done that.. 99 Nassau blue
Old May 9, 2005 | 11:12 PM
LS9's Avatar
LS9
do you have air tools ?
If so, about an hour .
Old May 10, 2005 | 12:54 AM
Jeff Jeff's Avatar
Jeff Jeff
It is an easy job. Make sure when you torque them, you torque them slowly. If you tighten too fast, you will get a false torque reading and end up with "clunking" noises -- it will sound like your suspension is about to fall apart. Torque them slowly to final torque and repeat several times and you will be OK.
To sway bar end links
