Help with spark plugs??
Old May 8, 2005 | 08:39 AM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Help with spark plugs??
The last time I replaced spark plugs was on an iron motor. I'm new to the LS1 and I've heard a few horror stories. My car has a little over 50K on the clock and I believe it's almost time to change the plugs. I will admit I'm apprehensive. Anyone have some good, safe techniques?
Thanks in advance!
Old May 8, 2005 | 08:45 AM
vetteamerica's Avatar
vetteamerica
The right tools make a world of difference!
Get a spark plug socket with swivel all in one
Get a small handle (palm) ratchet with a handle that moves (swivels back & forth)
These two items will help make it a little eisier
Old May 8, 2005 | 08:48 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep...#7 is the only PITA....use some anti sieze on the plugs as well
Old May 8, 2005 | 03:31 PM
magredZ51's Avatar
magredZ51
Snap-On : double swivel sparkplug socket, 5/8 size.
$55.00 and worth every penny. It made the job ez.
Plug wire removal was more difficult. I broke several.
Definately apply antisieze on threads. And carefully snug plugs, do not overtighten. It's almost impossible to use a torque wrench on many of the plugs. Dielectric grease on both ends of wires.
Old May 8, 2005 | 03:38 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you have 2 good extensions and a knuckle, you'll have no problem. None of the plugs, NONE will give you a problem with the knuckle.
Good luck
Old May 8, 2005 | 03:41 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Make sure the motor has cooled down. I haven't seen it on LS1 heads but I have seen the threads come right out with the plugs on other aluminum head motors when they are pulled hot.
To Help with spark plugs??
