Plug Gy Runflats???
Old May 8, 2005 | 03:16 PM
Dragon-Vette's Avatar
Dragon-Vette
Default Plug Gy Runflats???
Took all wheels off today to paint calipers...noticed 2 nails in my left rear ...both nails are close to center of the tread....will it be alright to remove the nails and put plugs in or should these tires be pached.
Thanks,
Jack
Old May 8, 2005 | 04:34 PM
IFLUBYU's Avatar
IFLUBYU
Thanks,
Jack
Take it in to get patched right. I like doing things old school, but plugs just dont belong on a high performance auto.
Good Luck!
Old May 8, 2005 | 08:11 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Old May 8, 2005 | 10:10 PM
loudsam's Avatar
loudsam
I plugged one once on the Kansas turnpike about 3 in the morning in below freezing temperatures. I ran the tire till the threads were showing through 10,000 miles later. I never even thought about it again. I don't know about the safety factor, especially at high speeds, but, the plug obviously held.
Old May 8, 2005 | 10:16 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
The first one I had done was a patch on the inside but the tires only had about 10K on them. The next time (same tire)....I thought I'd be replacing them soon so we plugged. I'd guess I've put about 20K on that tire since and never had an issue. Patching is the Ideal fix...but a plug will do in a pinch.
Old May 9, 2005 | 01:50 AM
LS9's Avatar
LS9
plugs work fine if installed correctly
Old May 9, 2005 | 10:04 AM
SGT. PYLE's Avatar
SGT. PYLE
Thanks,
Jack
Exact same thing happened to me a few weeks ago!!! Two patches and a balance at Tire Kingdom for $29.14.
Old May 9, 2005 | 10:24 AM
vetdude's Avatar
vetdude
Patched a vulcanized from the inside is the only way (and only legal way in MD) to repair the nail holes safely.
Old May 9, 2005 | 12:07 PM
Mr. Jones's Avatar
Mr. Jones
GY says patch it
Old May 9, 2005 | 01:17 PM
F1_SS's Avatar
F1_SS
I had a patch on my GY F1 Super car tire and it hold pressure fine.
Old May 9, 2005 | 01:22 PM
chazzvette's Avatar
chazzvette
......plugged left front after a screw found its way in, that was about 300 mi. ago. Take your time and do it right.
Old May 9, 2005 | 01:59 PM
TEXHAWK0's Avatar
TEXHAWK0
I always take the time to pull the tire off and patch it from the inside. Most places now are using a combination patch/plug that is one piece so that it has the advantages of the patch, plus it seals the cord area to prevent water from getting in between the layers and degrading the tire.
Also, a lot of places, like Discount Tire, will only patch a high performance tire 2 times. After that, you have to replace the tire.
Old May 9, 2005 | 07:31 PM
C5XTASY's Avatar
C5XTASY
This is true. There is a special patch/plug that is supposed to be used. Also, as you mentioned, they will patch twice. After that, the tire loses it's speed rating. Same thing with using a plug, instead of a patch. You do not retain the speed rating of the tire. Using a plug, the tire may run fine for a long time, and maybe, forever. It may also deflate at high speed...not my choice, I want to be able to trust the tire. I don't drive my C5 like I drive my Explorer. Tire stresses end up being quite a bit higher on the C5, it's why I don't mess around with tires.
Ed
Old May 9, 2005 | 07:48 PM
Dragon-Vette
Thanks for all the replys ...not to much longer till I have to replace the tires anyway.(2-3months(with some Khumos I think))...so might try and get by with a plug for now...found anouther nail in one of the fronts also
Thanks Again
Jack
To Plug Gy Runflats???
