Bilsteins...sport or regular?
Old May 9, 2005 | 01:01 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default Bilsteins...sport or regular?
Is there a way to tell the difference externally between the sport and the normal bilstein's?Also,do they both have the shorter shaft installed?
I bought a used set and owner not sure which it is...
Most seem to go with the sport shocks..are those a lot stiffer...or I guess I need to know why they are more popular
TIA
Old May 9, 2005 | 02:16 PM
yellow01's Avatar
yellow01
Sports are stiffer and are tailored to a lowered vehicle. Bilstein does not recommend HDs on a lowered car.
I have no idea if you can tell externally sorry.
Old May 9, 2005 | 03:10 PM
flynbya2's Avatar
flynbya2
Thanx yellow1,
anyone else know if you can tell which ones they are externally?
Old May 9, 2005 | 04:23 PM
flynbya2's Avatar
flynbya2
OK, here is what I found out. There should be #'s stamped in the shock body.According to Bilstein's website,here is what gives..for anyone else whom may want to know.......
..............................Front..... ........................... Rear
HD's .....................BE5-2795 ............................BE5-2796
Sports ..................BE5-2797.............................BE5-2798
Hope this may help others out!!!
Old May 9, 2005 | 04:45 PM
WKMCD's Avatar
WKMCD
Sports with Z06 sway bars...
Old May 9, 2005 | 04:49 PM
kedvesh's Avatar
kedvesh
I daily drive mine and have no problem with this combo.
Old May 9, 2005 | 08:31 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
The Heavy Duty Bilstein shocks are FRONT: BE5-2975 and BE5-2976
The sports are FRONT: BE5-2977 and REAR: BE5-2978
It looks like the Bilstein website is wrong.
Hope this helps clarify.
Thanks!
Shawn
Old May 9, 2005 | 09:07 PM
lar66BB's Avatar
lar66BB
Default Shocks
I heard somewhere that the sports are the same as Z51 factory shocks.
Old May 9, 2005 | 10:13 PM
flynbya2's Avatar
flynbya2
Thanks!
Shawn
UH...no :o :o
Looks like I transposed the numbers when I transfered them from the tablet to this screen
Thanx for so kindly pointing this out
To Bilsteins...sport or regular?
