torque mangement
Old May 15, 2005 | 02:13 PM
zapman123's Avatar
zapman123
Default torque mangement
people are claiming .3 seconds improvement
in 1/4 mi run with torque manangment system bypassed.
Seems like the cheapest mod going.
Why would GM do this?
Old May 15, 2005 | 02:37 PM
Special K's Avatar
Special K
You will not gain .3 in the quarter. Maybe .03/.05. It prevents the timing from retarding during hard accelerations by removing it. Torque Management is supposed to help prevent early mechanical failures. It makes life easier for the transmission.
Old May 15, 2005 | 04:42 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Does this apply to just A4's or can you do the same with an MN6?
Old May 15, 2005 | 05:05 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
It applies to MN6 and MN12. Less than it does to A4s though.
Old Jul 11, 2005 | 07:40 PM
00Veech's Avatar
00Veech
Is This something that Needs To be tunned away or is there a DIY method?
Old Jul 11, 2005 | 08:56 PM
chriswtx's Avatar
chriswtx
Old Jul 11, 2005 | 09:53 PM
Mike Mercury's Avatar
Mike Mercury
I think your are confusing traction-control with torque-management.
Old Jul 12, 2005 | 02:29 AM
shurite44's Avatar
shurite44
I agree. No way will you see more than a tenth. Hey Bob how is it going? I saw Sandra was questioning your sport car expertise.
Old Jul 12, 2005 | 02:31 AM
shurite44's Avatar
shurite44
You know it does not even apply to me but I have seen so many posts differing on this subject. Mike, does the manual have torque management?
Old Jul 13, 2005 | 10:54 PM
00Veech's Avatar
00Veech
Well, I know My Car has TM because It wont even let me Stall it up With the Brake to launch it
So is there a DIY Method or Tune only?
Old Jul 13, 2005 | 11:36 PM
gojo's Avatar
gojo
Why do you say that? He's right. Torque management instructions for A4 and manuals. The difference is the stock settings are less intrusive for the manual trans.
In the trans tab: under abuse mode raise rpms to 7000. Zero torque reduction and Upshift torque reduction. Your sure, now, that this function is gone.
In Eng. Cal.,torque control: Raise Max torque to 639. Abuse mode test, rpms to 7000 and speed to 0. Torque reduction all 0, TRQ by gear, tip-in and max engine trq all to 640. Leave TCS alone, since you can switch it off in car.
Old Jul 14, 2005 | 03:46 AM
shurite44's Avatar
shurite44
Thats odd, I power brake mine all the time with no problem.
Old Jul 14, 2005 | 05:06 AM
patmo's Avatar
patmo
All c5's came with t/m except the z06. Now most are finding out why the z06 seems so much faster than a stock c5. The minute I deleted it my car was very easy to get out-of-control. In the A4's is takes 30deg of timming out just for every shift! That was how I noticed it. I then downloaded a z06 file and did some comparing and found the z06 has no torque managment just tcs. if you would like me to elaborate I will but it is late and I'm going to bed.
Old Jul 14, 2005 | 04:59 PM
gojo's Avatar
gojo
Patmo,
The Z06 file I'm looking at does have one element of TM. It's abuse mode. It's the only element that has values.
Joe
Old Jul 14, 2005 | 08:39 PM
Mike Mercury
from what I've read; manuals only have "abuse mode" - and that's not an easy thing to get activated. But if you increase the power of the stock engine; then it does make it much easier to get into the abuse mode. And this weas for the 2001 and newer factpory PCM software. Before 2001... I don't know.
I have no links - and am going from memory.
For those that think removing TM will make a world of difference with a somewhat stock MN6; then lets see the links to pages that verify this, and explain EXACTLY what the PCM does to limit torque on the MN6 C5.
what year is your C5??? Because that may not be TM... it could be the TCS system causing that.
Old Jul 15, 2005 | 12:48 AM
00Veech's Avatar
00Veech
its a 2000
To torque mangement
