How is the Vortech Rammer Air Intake.
Old May 15, 2005 | 10:00 PM
Raced Guy's Avatar
Raced Guy
Default How is the Vortech Rammer Air Intake.
I found a really good deal on a vortech rammer intake with the air bridge and was wondering how good it is, what kind of gains? It seems like its similar to the vararam with the whole ram air set up, correct me if im wrong. Let me know what you guys think about it. Thanks
Old May 15, 2005 | 10:02 PM
Jserman's Avatar
Jserman
I have it on my car and like it.. I came with the car when I bought it..
From experience any intake is going to help you out.. one might be a little bit better then some.. but if you can get a good deal I wouuld say jump on it...
Old May 15, 2005 | 10:41 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I've had it on my car for two years and I love it. It gets only cold air from outside the engine bay w/o blocking my Z06 screens for engine cooling while at the track.
Old May 16, 2005 | 03:11 AM
Mitch C's Avatar
Mitch C
The Vortex rammer will give you some gains however it is a bottom breather. Several members have hydro locked their engines while using the Vortex Rammer. If I were you I would go with the Vararam if I was going to go with a cold air intake. The Vararam is not a bottom breather and is less likely to cause hydro lock.
Old May 16, 2005 | 03:54 AM
yellow01's Avatar
yellow01
I have had it for a total of 4.5 years on two C5's and never had issues, including through major rain.
I've heard the hydrolock stories but frankly am curious how in the world they occur. True, the opening's on the bottom, but the filter is above the level of hte radiator shroud, or in other words, a long way off the ground. If you're plowing enough water with the air dam to drive it up that far...
The other nice thing about the vortex is you can now get them cheap. The vararam is the current 'hottest intake' (I've seen many over the years) so many are selling their vortex's on the web.
Also, see the post by A&A regarding the vararam filter...
Old May 16, 2005 | 05:09 AM
Mitch C's Avatar
Mitch C
Driving thru heavy rain is not the problem with the Vortex. It's when you drive thru a deep puddle or standing water that can cause your engine to hydro lock. As far as the Vararams filter goes, just use a K&N filter for everyday driving and you won't have a problem. The foam filter should not be used for everyday driving.
Do yourself a favor do a search on hydro lock & CAIs. Then draw your own conclusion about which CAI to go with.
Old May 16, 2005 | 02:04 PM
BayouVette's Avatar
BayouVette
I've had it for 3 years with absolutely no problems.
Old May 16, 2005 | 02:16 PM
Special K's Avatar
Special K
Mitch, are you saying the Vararam is NOT a bottom breather? If so, how do you define a bottom breather?
Old May 16, 2005 | 02:35 PM
Mitch C's Avatar
Mitch C
The Vararam is not a bottom breather, since it draws air from the front of your car(the grill). The Vortex is a bottom breather because it draws air from below the shroud once you cut a hole in it. Any of the CAIs that draw cooler air in this manner are considered bottom breathers (at least that is my understanding).
Old May 16, 2005 | 02:57 PM
Special K's Avatar
Special K
Thanks Mitch. I see where you're coming from. I would call the Vararam a bottom breather and the Vortex a breather. Reason is that the Vararam intakes air at the bottom of the car.
Old May 16, 2005 | 10:57 PM
Blue Lion's Avatar
Blue Lion
A friend had one on his C5 and liked it.
Old May 16, 2005 | 11:32 PM
04BlueGoose's Avatar
04BlueGoose
Had one on my 97 for 5 years with out problems and I did ALOT of driving in heavy rain.
If you like this style look at West Coast Corvette's Hurricane
for around $299.00 or Callaway's Honker for $499.00
If you go to Carlise in August you will find the Vortex used from $125.00 and up and a new one for Under $200.00.
Vararam will cost you somewhere around $325.00 shipped plus the K&N(an absolute must) @ $45-$60.00
Good luck
Old May 17, 2005 | 03:26 AM
yellow01's Avatar
yellow01
It's the opposite.
The opening for the vararam is at the front of hte car, not underneath it.
The vortex takes air from underneath the car.
It should be noted that there is significant variation in the location of the filter in the so called CAI intakes for the C5. This will affect the risk of water injestion.
While the vortex takes air from underneath the filter is above the level of the shroud, essentially in the same place as the blackwing but open. In some of the Halltech versions the filter is much lower.
Old May 17, 2005 | 06:08 AM
Punisher's Avatar
Punisher
Not to highjack this thread, but is the Halltech rammer a good intake.....I was thinking of either the Halltech or Vortex rammer.
Old May 17, 2005 | 08:52 AM
newgene's Avatar
newgene
Here we go again... I have the Vortex intake, and the inlet for the filter appears to be higher then the location of my screens, which are by the fog lights. So, I would say the inlet for the Vortex is higher then the Vararam (if it is truly down by the fog lights). However, that is just the air inlet itself. The location where the greatest delta pressure occurs, which is where I call the actual location to be concerned with, is probably the same on both of them. Others should be able to chime in on this one. Although I don't have the Vararam, if it is located where I believe (by the lights), it is the same height or lower than the Vortex.
However, I've heard they both work very well. I have the Vortex and it rocks. I think everyone prefers whichever one they have because they all seem to work well. The performance difference between the two is probably negligible.
Old May 17, 2005 | 09:42 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
I switched from a Vararam to a Vortex to accomodate my Accusump install. Felt practically no difference in performance.
To How is the Vortech Rammer Air Intake.
