No codes, intermittent rough running
Old May 16, 2005 | 02:54 PM
lotzahp's Avatar
lotzahp
Default No codes, intermittent rough running
I hate intermittent stuff - especially when there's no codes to give me a clue.
My '98 with 34k miles started to run real rough intermittently. Kinda felt real low on power, and would hesitate/stumble at idle when it occurred. It seems like it was starved of fuel, but it would only do this under about 2000 rpm/25mph. If I stabbed the pedal or downshifted to increase rev's it would run fine.
The only codes I have are history ones for the LDCM and RDCM losing communication. So not much to go on there. Never have seen a Check Engine light or Reduced Power message.
In my search, I have put together this list of things it could be:
Fuel Pump/Fuel Filter
Throttle Actuation Control module
Mass Air Flow sensor
Throttle Position Sensor
MAF harness being shorted on fuel rail bracket
My thoughts/observations:
- A fuel related problem should not make the symptoms better with acceleration, such as I have seen. So this isn't it.
- MAF looks clean because I pulled induction system apart to inspect
I'll look at the harness tonight. Can I check the other 3 things somehow? (MAF, TPS, TAC)
Old May 17, 2005 | 01:40 AM
Black$heep's Avatar
Black$heep
Ttt
Old May 17, 2005 | 04:32 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
bad plug wire?? plug....also check to see if one of your plugs may have backed out a bit...sounds stupid but..BTDT...
Old May 17, 2005 | 02:41 PM
2KVetteMan's Avatar
2KVetteMan
Like stated check your plug wires.
Old May 17, 2005 | 03:04 PM
vetdude's Avatar
vetdude
Bad gas? Has a lot of rain lately? Moisture in the tank. I would try a couple of bottles of Dry Gas or Techron Fuel System cleaner first before replacing the expensive stuff.
Old May 28, 2005 | 01:53 PM
lotzahp's Avatar
lotzahp
Here's an update to my persistent problem.
The hesitation progressed into what seems like half the cylinders running, or a lot of misfire. It smokes like crazy after just a few minutes of run time. It is running very rich (heavy fuel smell).
I unplugged the MAF and ran without it. I also replaced all plugs & wires with new. Same symptoms.
After it got this bad, I finally got a new code: P0134 O2 Sensor B1 S1 Insufficient Activity.
So I replaced that O2 sensor with a new one. SAME PROBLEM!
Any other ideas?
Old May 29, 2005 | 05:35 PM
lotzahp's Avatar
lotzahp
And one final update: problem fixed!
The engine coolant temp sensor connection was either loose or dirty. I pulled it, cleaned, reseated, and everything is perfect again.
I don't know why a code for that wasn't set. And I guess the rich condition tricked the 02 sensor code.
Old May 30, 2005 | 09:01 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Glad to hear you figured it out!! Thank You for sharing your findings as well.
VR
To No codes, intermittent rough running
