When putting on my B&B headers, I tore my original plugs and had to use one off of my dad's S10 until I get new ones. I think I have decided on red MSD 8.5 wires but not sure if I need the regulars since the headers are shorties or the "header wires." Also, who has the best price on these and how much? I'm going to the drag strip Thurs. so I need them soon! I prefer to buy them at a store but there aren't many parts stores around here (Advance and Napa). Thanks!
In my opinion, the stock wires are perfect. They are short and have heat shields to keep them from melting. I have yet to hear anyone post any gains from running other more expensive wires.
I ran the MSD wires for about a year until I started getting misfires. The heat from the headers deteriorated 3 of the wires. If you run something else, make sure you use cool sox or some type of heat shield.
Thanks for the replies. I'm not going for performance gains... just something to replace my bad stock set since the msds are cheaper than delco. Any other suggestions
With the B&B shorty headers be aware that the plug wire on the left-side #3 cylinder will touch the header pipe. I burnt through two factory plug wires ($28 a piece!) before deciding to go with a set of MSD 8.5mm wires. The MSD wires have an adjustable spark plug boot that allows you to bend the wire away from the header. In addition, Cool Sox are definitely a good idea!
I installed MSD 8.5 regular length wires with BBK shorty headers on my 97 about 8 months ago, did not reuse the factory heat shields and have not experienced any problems thus far.
However the plug wire boots do not come close to the header pipes at all.
