Nitrous Question
Old May 16, 2005 | 11:17 PM
mitymikec's Avatar
mitymikec
Default Nitrous Question
I am thinking of putting a dry kit 100hp shot on my ls6 powered coupe. It dynoed 347rwhp last year at the wheels. I put a magnaflow exhaust on it since then and will put the jug on and was wondering what numbers others have gotten from this set up. Car ran 12.3 at 113mph. I also put BF drag radials 315/30/18. If anyone has similar set up let me know how it worked out for you>
Old May 17, 2005 | 04:34 PM
mitymikec's Avatar
mitymikec
Anyone have any imput?
Old May 17, 2005 | 04:39 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
You'll get at least a 1/2 second and prob more. What kit?
Old May 17, 2005 | 05:15 PM
mitymikec's Avatar
mitymikec
i want to use a NOS kit similar to the 5177. the kit is off my mustang dry kit
Old May 17, 2005 | 06:56 PM
mitymikec's Avatar
mitymikec
ttt
Old May 17, 2005 | 07:20 PM
Robert56@RNS
Collections Hold
The 5177 rates at the crank, so the 100hp jets give about a 75/80hp rear wheel hp. So the 5 tenths is about the area you'll see. Can up size later if not enough, but things to consider when going bigger with dry. The dry can be upgraded fully later, big single stage, dual stage dry, dual stage dry/wet or many other combos. If you have any questions PM, e-mail or ask on thread as I have lots of info on 5177 and the math. check out my web site pics and in links.
Old May 17, 2005 | 07:25 PM
mitymikec's Avatar
mitymikec
My buddy has a TNT ring kit on his vert and went from 13.2 to 11.39 on the jug. he sprayed 150 shot..i dont want to go form 12.3 to 11.8 by using this dry kit..
Old May 17, 2005 | 07:33 PM
mitymikec's Avatar
mitymikec
Is the fuel pressure swtich a must and is the realy a 4 or 5 prong relay?
Old May 17, 2005 | 07:53 PM
mitymikec's Avatar
mitymikec
ttt
Old May 17, 2005 | 10:08 PM
Robert56@RNS
Collections Hold
FPSS is a safety item, many do not use one. I do, but they can sometimes be problematic. Yea relay is as you said. I have a schematic to show what number per prong is for what if needed. My PM is working again also.
Old May 17, 2005 | 10:53 PM
mitymikec's Avatar
mitymikec
ttt
Old May 18, 2005 | 01:03 AM
Shylor's Avatar
Shylor
You might get a better response if you post it in the C5 Forced Induction/Nitrous section. http://forums.corvetteforum.com/forumdisplay.php?f=86
Old May 18, 2005 | 05:30 AM
FASTENUF's Avatar
FASTENUF
I gained 6-7/10ths with a 100 dry shot
Old May 18, 2005 | 11:40 AM
t56gen3's Avatar
t56gen3
You can run a 100 dry shot all day long with no issues, just throw in some TR6 plugs and spray BEFORE the MAF sensor. The PCM will compensate.
To Nitrous Question
