My passenger side driving light quit working and the right turn signal blinks rapidly. I thought it was just a burned out bulb and went to replace it, but I can't figure out how to get to the bulb. Any ideas on how to reach the bulb?
Thanks,
Tom
The daytime running light (driving light) and the turn signal are different bulbs located in the same housing. The rapid blinking turn signal indicates a turn signal bulb is probably burned out. Turn on your emergency flashers to find the non-working light. You can access both front bulbs, if your arms are long enough and skinny enough via an open hood. The rear turn signals are a piece of cake. The bulbs twist about 1/4 turn before coming out of their housings. The isn't much slack in the wires, so don't yank on them. The bulbs pull straight out of their sockets. It is a minor PITA job to do the fronts. If your fog lights are burned out, you can reach through the front brake air inlets to get to them.
