I was told to clean the area around the bleeder well (old bleeder on caliper) .
keep the cap on the resivour (to help keep fluid from running out as fast)and remove the old bleeder, install new speedbleeder and snug down.
then to bleed, open speedbleeder 1/4 to 1/2 turn and pump brakes
(I put a hose on the bleeder , route it to a jar with brake fluid in it and make sure the hose in in the fluid to add that no air will get in the system.)
pump the brakes steady full travel (as you would pump in bleeding the brakes)
allow a few seconds between pumps.
if you use a clear hose, it is possible to see the old dark fluid turn clear as the new gets through the system. (even easier if you use colored
fluid)
when done with that brake, go tighten the bleeder. repeat for other wheels
if you use a hose, it keep the mess down ....
I did all of my brakes in about 1 hour, that included removeing the wheels...and they work great.
someone else might chime in with GM sequence for bleeding , I usually go to the farthest from the master cylinder first.
not sure if you can install the bleeders with wheels on, but I think you can...it may be possible to do .
Speedbleeders are great. They let you bleed the brakes by yourself and are very easy to install. There is no need to have the hose connected to the bleeder valve submerged in brake fluid as the mechanism in the speedbleeder stops the backflow. Makes it very easy to bleed.
Thanks for the replies. I am much more confident with this project now
I got mine from Mid America Direct. Some folks say you can get them at Pep Boys but I struck out. But I did pick up a NOS steering wheel cover and some bullet hole stickers good for 45rwhp
I bought two set at $17.99
Good luck.
S.
I got a set of speedbleeders from Pep Boys a set of 4 were $20.00. Make sure you get the proper size. Pep Boys' item number is 12706 and the size is thread:M10x1.0, Overall lenght: 33mm. This is very important or you may end up with the wrong ones. That's my $0.02
fluid)
when done with that brake, go tighten the bleeder. repeat for other wheels?
97-00 RR,LR,RF,LF
01-04 RR,LF,LR,RF
it probably could be done, but I wouldn't try it, especially if it's the first time you've done any work on you brakes, plus it's a good opportunity to inspect everything. I do leave the rear wheels on to bleed the brakes, just lift the front and reach up behind the wheel and do it by feel, but when I started doing it, I would take each wheel off so I could see what I was doing.
most of the forum vendors sell them, makes bleeding the brakes a lot easier
I agree with using a clear vinyl hose (1/4"ID) to keep from making a mess. One tip on the hose: Using a glass jar with a metal lid, punch/drill a hole in the lid that is just barely big enough to insert the hose. That way the hose doesn't keep trying to "flip" out of the jar and the weight of the glass jar helps hold it in place while you're working. I have done mine several times without removing the wheels.
Another tip: Re-use your little rubber protective caps after you install your Speedbleeders. HTH
