Weird Active Handling Problem
Old May 18, 2005 | 04:11 PM
jwg2's Avatar
jwg2
Default Weird Active Handling Problem
I'm having an issue with my Active Handling System applying the right or left front brake when it is not needed. This occurs when I am cruising down the highway at steady speeds, traveling in a straight line.
When it occurs, you can feel either the right or left brake being applied momentarily, and the car will witch in one direction or the other. The DIC will flash "Active Handling" as it occurs.
I had the car into the shop, and they said they found a bad connection, which they repaired. Sure enough, 50 miles out on the road, the problem reoccurs.
My Actron is showing that no codes have been set. Referring to my chassis service manual, I would have expected any one of the variety of yaw sensor errors (C1281 through C1288).
Has anyone experienced this before? If so, how was it resolved?
Old May 18, 2005 | 04:47 PM
2000BSME's Avatar
2000BSME
sounds to me like you have unequal tire diameters or inflation pressures. Just a guess, but I would look into it.
Old May 19, 2005 | 08:51 AM
jwg2's Avatar
jwg2
interesting, I hadn't thought about that. All the tires were pretty much right on the mark. One tire had an extra two pounds in it. I would think that the AH would be able to handle that difference, but who knows. I've let a little air out of the offending tire and I'll let you know how the next test drive goes.
Old May 19, 2005 | 12:23 PM
Ranger's Avatar
Ranger
Is your wheel/tire combo stock?
Old May 19, 2005 | 01:41 PM
jwg2's Avatar
jwg2
yes. been running toyo proxes for about 15000 miles, but they are the recommended size.
Old May 19, 2005 | 01:53 PM
Ranger's Avatar
Ranger
Your AH issue is one I've not had on any of my C5s.
But I'd suspect a bad sensor or a loose wire to a sensor.
I'd take the car in to the dealer.
You'll need to prep the service advisor and tech that the problem is intermittent, so that they won't return the car as is, with the ticket marked "unable to duplicate the problem."
Ranger
Old May 19, 2005 | 02:27 PM
allanlaw's Avatar
allanlaw
Take it to the dealer and indicate that this is a serious matter. I have a friend who had the AH lock one of the front wheels on a freeway offramp at around 50pmh and the car was totalled when it hit the wall.
Old May 19, 2005 | 02:37 PM
jwg2's Avatar
jwg2
I do plan on taking it back to the dealer again, but I'm hoping the combined brain power of the forum can solve this, because the dealer obviously needs some help diagnosing this.
Old May 19, 2005 | 06:39 PM
shurite44's Avatar
shurite44
Danger Danger Will Robinson. I would be afraid to drive it with the described condition. And that's no joke.
Old May 19, 2005 | 06:51 PM
Ranger's Avatar
Ranger
Here is a start.
A GM release on Active Handling
I took a few minutes to find the relevant passages in the Corvette Service Manual. You want Vol 1 of 3; page 5-190 and 5-191, entitled "Vehicle Stability Enhancement System Unwanted Activation (w/JL4)."
Read that, and if you can understand the details, it will poop you up for a conversation with dealer personnel.
If someone has the manual and a scanner, perhaps they can email him a pdf.
Ranger
Old May 20, 2005 | 08:25 AM
jwg2's Avatar
jwg2
Here is a start.
Ranger
no need to scan, I have the manual. I've read the section, just puzzled why its not throwing codes.
Old May 20, 2005 | 11:34 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I had the same issue on my 02. Dont walk but run to your dealer the problem is with the Yaw rate sensor. This is very dangerous condition that can cause you to lose control on the car. I am 100 % sure the Yaw rate sensor which control the active handling is bad or malfunctioning.
Cecil
Old May 20, 2005 | 11:52 AM
jwg2's Avatar
jwg2
Cecil
that was my sense as well. were you getting error codes however? I suggested this to the dealer on my first trip and they said it was ok, but they may have been just looking at the codes and not actually testing the sensor.
Old May 20, 2005 | 01:06 PM
Snake Slayer
Cruise-In V Veteran
Yes I did have codes.
Old May 20, 2005 | 02:09 PM
jwg2's Avatar
jwg2
heh, I was afraid you were going to say that. Mine has never thrown a code (for all the complaining I did about OBD II, I sure do lean on it now). I took the advice of 2000BSME and adjusted tire pressures, and it did not act up on a very short test run. Who knows, maybe that was it, but I tend not to trust inexpensive solutions on my complicated car
Old Jun 8, 2005 | 07:50 PM
jwg2's Avatar
jwg2
sigh. the problem persists.
I've taken the car back to the dealer. they replaced a second, different connector and said I was all set. 5 miles down the road, the same problem again. I think they are helpless/hopeless without an error code.
I'm ready to unload this car and by my C4 back.
Old Jun 8, 2005 | 08:11 PM
Ranger's Avatar
Ranger
Which dealer are you using?
Ranger
To Weird Active Handling Problem
Old Jun 8, 2005 | 08:17 PM
jwg2's Avatar
jwg2
Ranger
I've used Bob Peck. They don't do a lot of vettes from what I can tell, but they've done a good job thus far. This is the first time I've been unhappy with results. I'm betting Criswell or Koons are more likely to have seen this problem, but I've had extremely unpleasant experiences at both and just as soon not take my business there.
I'd do all the work myself if I didn't have the warranty. When using the dealer requires more effort than noodling through it myself, we have a problem.
Old Jun 8, 2005 | 08:34 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
....don't give up so easy. It hasn't cost very much so far and that's a good thing with these cars. Ask around at a local corvette club for a good place to take your car for repairs. These guys usually know the better shops in the area. You might want to buy a yaw rate sensor and install it as a next step. You've trouble shot some wires, if the sensor isn't too expensive give it a try.....Good luck......
Old Jun 8, 2005 | 08:47 PM
Ranger's Avatar
Ranger
I'd suggest calling Criswell and asking to speak with Bob Wisman who is the Service shop foreman. Bob also is an accomplished road racer that knows C5s very well. Tell him your symptoms and ask if he thinks Criswell can solve the issue. If he says "yes," believe him.
Ranger
