Quick Question re Fog Light Replace...
Old May 18, 2005 | 09:44 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Quick Question re Fog Light Replace...
Pass side is out...haven't crawled under the car yet...is there a bulb to replace? or replace the light fixture.....installed Z06 screens so I can't see much from the front.
thanks
Mark
Old May 19, 2005 | 01:08 AM
MAC5's Avatar
MAC5
You can get to them from the top. Raise the hood and headlamps, leave the headlamps in the up position. You can see the socket for the fogs below the headlamp on the front facia. The socket twists out. A good replacement bulb is a #885, they are rated at 50watts vs. the stock 35 watt bulbs. Just be careful not to touch the glass on the bulb when replacing. If you have the time, the change out is easier if you remove the black bezel from the headlamp assembly. It gives you some additional room to get your arm down there. Good luck.
Old May 19, 2005 | 08:23 AM
TOPGUN9's Avatar
TOPGUN9
What he said...
Old May 19, 2005 | 08:41 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
better have small arms or hire a kid to get in there if you don't remove the headlight cover and black bezel.
I have the 885s in mine and they are much brighter. I believe the stock fogs are for a trail blazer and have a cap over the front end to deflect the light. The 885s do not have that cap.
Also you might want to adjust the height of the fogs since they are too low from the factory....
Old May 19, 2005 | 09:42 PM
mbeeman350's Avatar
mbeeman350
Again thanks to all...with all the advice it was a piece of cake to change this bulb....this is the best Vette site....bar none!!!
Mark
To Quick Question re Fog Light Replace...
