Q's: About 342 Gears
Old May 21, 2005 | 11:15 PM
griffgoody's Avatar
griffgoody
Default Q's: About 342 Gears
I have a friend that has 373 gears. At a dead stop, he can peel rubber in 1 and 2(auto). I also hav a 98 auto vert with 342's. From a dead stop, my car want spin with traction control on or off in 1 or 2. Is this right for 342's not to spin in 1 or 2 in a slightly moded vert.
Old May 21, 2005 | 11:20 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Your 3.42s offer you better traction than your friend's 3.73s. Not unusual that he would get more wheel spin than you.
Old May 21, 2005 | 11:22 PM
C5magic's Avatar
C5magic
With 3.42 gears you should be able to spin your tires, assuming you are running stock run flats. If there is a tuner near you have your car checked. Your car sounds like it might be down on power. Or some other tuning issue.
Old May 21, 2005 | 11:34 PM
Irish Whiskey's Avatar
Irish Whiskey
A4,3.42's - with traction off, they will melt my GS D3"s.
Old May 21, 2005 | 11:38 PM
blackbelt's Avatar
blackbelt
John when did you get the 3.42's ?? Hope the car is running good let me know how everything is going..
Old May 21, 2005 | 11:40 PM
griffgoody's Avatar
griffgoody
I'm not running run flats and I just installed vararam and tpis headers. I guess I need to get the car tuned again. Even when I got a street tune for the 342's/air/fuel/shift points/etc... the car has never spun from a dead stop or roll. But the car runs strong.
Old May 21, 2005 | 11:45 PM
C5magic's Avatar
C5magic
You definately should get your car tuned. After installing headers your engine will often run too rich costing you HP. If you really want to wake up your car install a high stall T/C.
Old May 21, 2005 | 11:56 PM
griffgoody's Avatar
griffgoody
I'm waiting for a ssyank 3200 as we speak from a forum members car. Only 600 miles for $600. Buying from NUZZ.
Old May 21, 2005 | 11:57 PM
griffgoody's Avatar
griffgoody
What all do you have on your car as far as mods.
Old May 22, 2005 | 12:01 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
I melt my tires in 1st or 2nd with 295 F1s and 3.42s. I dont see a need to go with shorter gears becuase even with DRs i leave 20ft black marks in 2nd.
Old May 22, 2005 | 12:02 AM
griffgoody's Avatar
griffgoody
Hey Michael, car's running good, just need tuning after vararam and headers. I hope that will pep it up some.
Old May 22, 2005 | 12:05 AM
griffgoody's Avatar
griffgoody
Do you have a yank or vig t/c. Or, are you running a stock stall.
Old May 22, 2005 | 08:24 AM
Irish Whiskey
Blackwing, Kooks headers w/high flow cats,Corsa Indy Tigersharks, 3.42 gears and hardened shaft - smoked the GSD3's last year without the headers- just took off the traction control, sat still,stomped on it and applied the Goodyear rubber to the road!!
Old May 22, 2005 | 09:43 AM
Shawn MacAnanny
Mine's a Z06, so manual. Not dumping the clutch just flooring it once moving it starts spinning and shifting into 2nd and flooring it does the same.
Old May 22, 2005 | 09:50 AM
Mike Mercury's Avatar
Mike Mercury
Heck, with my original 3.15 I could get tire squeal when punching-it from a stop. Not much though, but it would chirp the tires. With my 3.42 (still using the stock tires and TC) there's no problem at all.
Here is a video of a girl driving my 2002 just after the 3.42 upgrade (and that was the only mod at the time the video was taken):
http://hometheater.home.att.net/ohiogirl1year.mpg
(of course, traction control was turned off via the DIC)
Granted; in order to seriously melt the factory tires, I would still need to start it off with a little bit of power-braking first.
Smoking tires may be a cool visual effect, but it makes one a lose in a drag race.
Old May 22, 2005 | 12:09 PM
griffgoody's Avatar
griffgoody
Hey Mike, I use to get a squeal or chirp every now and then when it shifted into 2nd, but now after the vararam and header install it want do either. I think I need to get it re-tuned. The car feels and runs strong but hearing everyone talk on the forum, I should lay some black marks from a stand still than stomp.
To Q's: About 342 Gears
