Draining Radiator
Old May 22, 2005 | 02:51 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default Draining Radiator
OK, got to ask a dumb question...how do you drain the radiator in a C5? Can't find one of those turn valves anywhere on the bottom of the radiator.....
Thanks....
Old May 22, 2005 | 03:06 PM
ROJ#79's Avatar
ROJ#79
It's their! Rightside of Rad. Engine side. Not a standard petcock. It's black just like the Rad. I did mine last year.
Old May 22, 2005 | 03:09 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Thanks, is there something about having to bleed the air out of the system as or after you refill? I have a Cool-Flex chrome upper hose I want to put on but, starting to change my mind.
Old May 22, 2005 | 04:44 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Not to get off the subject, but how does that hose look in person? Thanks.
Old May 23, 2005 | 06:02 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Here's their site
http://www.coolflex.com/cfm/welcome.cfm
Old May 23, 2005 | 08:25 AM
c3andc5's Avatar
c3andc5
Yes. After refilling with coolant you need to run the engine for a while after the thermostat opens with the surge tank cap off to bleed air.
Old May 23, 2005 | 10:30 AM
jimcork1's Avatar
jimcork1
My drain plug was on the bottom of the right side of the radiator and was white with a phillips type slots in it. I used a phillips screwdriver and it only turned about 1/2 turn to open. I removed the cap. My engine was warm with the thermostat open. 11 qts. drained out of a 12 qt system. The coolant looked new (61K miles) and no trash in the coolant. I just closed the plug after draining,, and refilled. I measured 11 qts going back and the overflow tank is probably a little over full. I thought I would have to bleed it,, but It would not and has not needed any more coolant. That was about 2K miles ago. 99 Nassau Blue
Old May 23, 2005 | 10:45 AM
c3andc5's Avatar
c3andc5
I'm curious to know how you got 11 of the 12.6 qts to drain without opening the drain plugs on the engine block itself?
To Draining Radiator
