HVAC Question
Old May 23, 2005 | 06:34 PM
woody1243's Avatar
woody1243
Default HVAC Question
I know this has probably been seen before for the A/C threads but I need to know what this code means to repair the problem.
First this is a 99 vert and it has the infamous hot air our of the center AC vents. I have done the remove fuses 18 and 27 to try to clear the control head and still no joy. I have also cleared all the codes and the only one that is current is for the HVAC code BO441. Please help as this is my honey's car and we are in Florida. We really need to get this fixed soon. I know there are the gurus out there to help as well the experienced C% owners. Thanks gang in advance and cheers.....
Old May 23, 2005 | 09:15 PM
ronwc's Avatar
ronwc
If you have the dual air control and one side is coo and one is warm, it may just need freon. I went thru this about a month ago, reset all with fuses, gave up and took it to the dealer. Just needed freon, works great -
Old May 24, 2005 | 10:27 PM
newkid's Avatar
newkid
5th Gear
I don't know what to tell you. I have the same problem with my 99.
I just purchased mine about 3 month's ago and had to add about 1/2 can of R134 to get the A/C charged up. The passenger side is reading about 44 degees F and both driver side about 10 degress warmer.
To HVAC Question
