hey guys
well, found out i have a pin hole leak in my cooler line. its an easy fix, but im wondering, when i pull the line, how much fluid will come out of the line. is it going to be like 2 qts worth or like 10 qts worth???
the system isn't pressurized so you shouldn't have much coming out aside from what is in the line but it depends i would still have a drain pan ready cause your still going to have a bit come out a few qt's at least but not 10 qts.
Coast7: 3.5 qts??? thats it??? mine take 12 qts!!! i have a 4L65E though, so perhaps thats the reason...
1968Olds: thanks for the tip.
i plan on plugging the ends of the two lines as soon as i pull it off, as i want to reduce the amount of fluid to come out so i don't have to refill. from what i have experienced before, its a PITA to fill tranny fluid!
thanks again guys...now i can rest peacefully tonight! LOL
Aj
