what does this mean??
Old May 23, 2005 | 11:22 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
Default what does this mean??
i was looking at my gm service report and i was wondering what this ment? 323266 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 61645 miles
does this mean that the column lock has been serviced and performed at some point? i just got Column Locked. and i am making sure my car has not been serviced for column lock, before i go buy a CLB. if it has been serviced the CLB will not work correct!!
thx frank
Old May 23, 2005 | 11:27 PM
wannabe-psi
better yet here is my gm report history
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/12/2004 323266 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 61645 miles
01/04/2002 279356 # V0743 - ECL RELAY HARNESS REPLACE 31200 miles
02/28/2001 263531 # C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 20257 miles
02/02/2001 262302 # N0110 - BATTERY - ONE - REPLACE 19632 miles
02/02/2001 262302 # T2020 - TOWING 19632 miles
02/02/2001 262302 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 19632 miles
02/02/2001 262302 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 19632 miles
07/27/2000 252040 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 13677 miles
07/27/2000 252040 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 13677 miles
07/27/2000 252040 # K2823 - SEAL, INPUT SHAFT - REPLACE 13677 miles
07/27/2000 252040 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 13677 miles
02/09/1999 A19852 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
does anything look like column lock repair too you guys??
thx frank
Old May 24, 2005 | 01:24 AM
Shylor's Avatar
Shylor
I would say the 2004 reprogram is it. If you have a 6 speed, the recall fixed nothing so you could still use a CLB. If you have an automatic and are still getting column locks, then most likely your car did not have the recall done. Once you get the recall done on an automatic you won't need a CLB, as there will be no lock to bypass.
Old May 24, 2005 | 05:32 AM
wannabe-psi
thx for the info. will be ordering one today next day air
frank
Old May 24, 2005 | 02:42 PM
C5-BRUCE's Avatar
C5-BRUCE
Default Stand-by on ordering the CLB
04006 is the Column Lock Recall. If you had your car serviced, the dealer automatically checks your VIN number and [usually] performs any recalls without asking you. Since the SCL recall was spearheaded by the NTSB, and or NHTSA, it's designated as a Federal Safety issue. The list also shows the ECL (Electronic Column Lock) harness was replaced 1/04/02. This is the harness that will prevent the by-pass kit from operating.
Sorry, wish I had better news.
Bruce Miller
c5bruce@adelphia.net
Old May 24, 2005 | 04:56 PM
Cpe04's Avatar
Cpe04
CLAIM HISTORY
thx frank
How does one go about getting this history? I'd like to check mine also.
Old May 24, 2005 | 08:51 PM
wannabe-psi
pm sponge vette!! he will get it for you no problem!!
yeah this really bites. my car is at the dealership and will be there until wednesday . i was also talking to the wrecker as he was stealing my car , he told me that they pick up about 6-8 vettes a year for this same problem. he also stated that he has had only one repeat customer for this same problem!! the bad part is that i live in a city that only has a population of about 100k
thx frank
To what does this mean??
