Help! my HVAC smells bad
Old May 24, 2005 | 09:15 AM
saber's Avatar
saber
Default Help! my HVAC smells bad
My HVAC has a musty smell comming out of the vents.
My Chevy truck has a filter that can be replaced.
Does the Vette?
Has anyone had this and corrected it?
Thanks in advance.
Mark
Old May 24, 2005 | 10:04 AM
VetteTech81's Avatar
VetteTech81
Does the Vette?
Thanks in advance.
Mark
I've found alot of rodents like to climb into the a/c box and build nests. there is a product that you can spray into the system and it will help clean up and musty smell from storage. I believe there are a few varaiations out there available at most parts stores. we use a product from a company called Wurth I'm not sure it's available at stores or not.
-=Rick
Old May 24, 2005 | 11:33 AM
corvettebob1's Avatar
corvettebob1
Does the Vette?
Thanks in advance.
Mark
Make sure your drain tube is open, most of the time you get the musty smell it's pluged and sooner then later your carpeting will start getting wet on the passenger side.
It can be found coming through the firewall on the pass side right above the exhaust pipe.
Old May 24, 2005 | 02:03 PM
VetteTech81
Good point! I forgot about that.
-=Rick
Old May 24, 2005 | 03:56 PM
mike348's Avatar
mike348
Mold build up on evaperator. GM has a bulletin for it. Hvac fan cutoff switch delay. Dries up wet evaperater to keep mold under control.
Old May 24, 2005 | 11:54 PM
billmoore48's Avatar
billmoore48
Try this post
http://forums.corvetteforum.com/showthread.php?t=898288
To Help! my HVAC smells bad
