Fuel tank removal???
Old May 24, 2005 | 07:54 PM
jers98vet's Avatar
jers98vet
Default Fuel tank removal???
Has anyone totally removed their fuel tank to swap pumps? I've done a few swaps with the tank hanging and wanted to know what holds the tank up when the bottom shield is removed. i've tried pulling it down but was afraid I'd break something. Anyone know?
Thanks, Jer.
Old May 24, 2005 | 08:04 PM
ANTIVINUM's Avatar
ANTIVINUM
Good question. I as well would like to no so when my sending units go out AGAIN I can fix it. So TTT
Old May 24, 2005 | 08:46 PM
jers98vet's Avatar
jers98vet
ttt
Old May 24, 2005 | 10:13 PM
Dr. Dan's Avatar
Dr. Dan
Originally Posted by jers98vet
Has anyone totally removed their fuel tank to swap pumps? Anyone know?
If your car was made prior to Nov '02 your fuel pump is on the drivers side and you can access it through the wheelwell, no need to pull the tank. The '03s had a midrun change to the FFS fuel system located on the pass side. I have the instructions of the pre-FFS pump install that Magnuson supplied with my kit...unfortunately, I have a FFS system. Learned the hard way. PM me your address if you'd like a copy.
Dan
To Fuel tank removal???
