heads/cam question
May 25, 2005 | 09:18 AM
heads/cam question
I have a 99 coupe M6 and am looking to add some good power with heads/cam.
I don't really know much about heads and cams so my question is what specific cams and heads do I look for?
I want an aggresive streetable cam. I have intake and exhaust now but plan on adding an ls6 intake manifold/throttlebody, and LT headers.
May 25, 2005 | 10:31 AM
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There are a ton of choices. You need to be more specific on what you want. You need to decide how radical you want to go. I plan on doing either MTI Stage 2s and a R1 cam or AFR 205s and a X3 cam. I'm pretty sure both make about the same power. The MTI setup will cost less though.
May 25, 2005 | 10:41 AM
Cartek Racing (
www.cartek.net ) in NJ has had much success with their track and street proven heads and cam packages...give them a call.
May 25, 2005 | 10:43 AM
As mentioned, I do not know much about heads/cams. I will be road racing. I do want an aggresive cam and want good power gains.
I don't mind the car rocking a bit.
May 25, 2005 | 04:57 PM
As
cajundude already mentioned there's a TON of choices. What i would do first if find a tuner(s) that's close to home. Then go to thier website (located on left sidebar) and see what they offer....then do a search here on the forum to see user reviews regarding that setup.
May 25, 2005 | 06:41 PM
also goto LS1tech.com those guys know a TON!!! and they have tried every head and cam combo known to man also have the dyno graph to show LoL.
May 25, 2005 | 09:14 PM
How much RWHP are you looking for?
May 26, 2005 | 09:49 AM
I would like to be around the 400rwhp
May 26, 2005 | 11:41 AM
Quote:
You can get at, or near 400rwhp and still retain stock heads. Click on my Mods in SIG below.
May 26, 2005 | 07:47 PM
St. Jude Donor '12-'13-'14
I feel your pain
you can get right at 400RWHP with stock ZO6 heads and a TR224.
May 26, 2005 | 08:39 PM
Quote:
Originally Posted by phils C5 vette
I feel your pain
Z06 Heads?
I have 405RWHP with stock 2001 C5 Heads.
Although, I do have the 04 Z06 Stabilizer Kit installed.
