Looking For Empty Engine Bay Pics.
Old May 25, 2005 | 08:19 PM
IMD's Avatar
IMD
Default Looking For Empty Engine Bay Pics.
anyone have any? trying to see how the front k-member attatches to the frame on any C5.
tia.
Old May 26, 2005 | 07:57 AM
vetteheadracer's Avatar
vetteheadracer
2022 C7 of the Year Finalist - Unmodified
hope these help!
Old May 26, 2005 | 05:29 PM
SpeedyZ's Avatar
SpeedyZ
This may help. The chain is not factory! This is looking at the frame just ahead of the LF wheel. You can see there is a large bolt that runs through the frame from top to bottom. There is a pipe welded inside the frame that the bolt goes through to keep the frame from collapsing. There are four of these bolts, two through each frame rail. The bolts are locked on top so you don't have to hold the top while loosening the nuts. Just ahead of the bolt you can see a small aluminum dowel pin that locates the member under the frame. There is still quite a bit of movement when you loosen the bolts. The member under the rear of the car is mounted the same way as the front.
Old May 27, 2005 | 07:22 AM
IMD's Avatar
IMD
does the motor mount to the k member, or the frame? im putting C5 suspension on an S10 truck, hence all the wierd requests.
Old May 27, 2005 | 10:05 AM
ragtopws6's Avatar
ragtopws6
The motor mounts to the sub-frame. Sub frame mounts to the main frame.
Old May 27, 2005 | 02:52 PM
2000BSME's Avatar
2000BSME
Dude, (sorry, I hate it when people call me dude) but that is awesome. Please tell me that your going all the way and doing the rear suspension also. I love that kinda stuff.
Old May 27, 2005 | 06:41 PM
IMD's Avatar
IMD
yeah the rear stuff i already have, but im still debating on the front, it looks like it might be easier to use C4 front suspension, because with the motor mounting to the subframe, it may not work, because the wheel base is 4" longer than the vette. there would probably end up being a 4" gap between the torque tube and the engine. i dont know what im going to do about that. shortening is easy, but making all that stuff longer might be a problem.
To Looking For Empty Engine Bay Pics.
