Help diagnose my voltage problems
Old May 25, 2005 | 09:11 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Default Help diagnose my voltage problems
My car at idle jumps around between 10 and 13 volts and my exterior and interior lights flicker. I can't figure out what is causing my issues but figure it is one of the following.
1 - Low battery ? My car always come up to Odometer setting and I heard this is a sign of low battery.
2 - Alternator problems?
3 - CAM / Tune issues. I have a 226/230 cam so my idle is not exactly stock.
What should I address first?
Old May 26, 2005 | 09:10 AM
John's vette
Anyone ?
Old May 26, 2005 | 09:33 AM
cenzo's Avatar
cenzo
Well John, it could be #3 - given a serious "lope" and a low idle speed it might happen.
It could be low battery.
It could be bad grounds.
It could be the alternator.
Put up battery voltage on the DIC. It should read a steady 14 volts + or - a couple tenths at cruise.
With the car not running and the key on you should have 12 volts give or take a tenth or so.
Get these results and from there we can get more help.
Old May 26, 2005 | 03:26 PM
JoeyG's Avatar
JoeyG
Car off, measure battery voltage (it will be about 1/2 volt higher than dic). Start the car measure alternator output terminal voltage (1/2 volt higher than dic again). Now measure the battery voltage, should be exactly the same as alt voltage. Now on passenger side look towards the starter and verify the terminal wires are all tight. If everythig there looks good, alt and battery should be tested.
Old May 26, 2005 | 07:24 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I had a very similar problem on my '98, and it turned out to be the Alternator. Goodluck on your search.
To Help diagnose my voltage problems
