T/C verses Gear Change
Old May 25, 2005 | 10:46 PM
glind46677's Avatar
glind46677
Default T/C verses Gear Change
I have a 2004 vert with 273 gear. Only mods are kooks headers, B&B exhaust, X pipes and Vararam induction. Would a T/C help me without changing the gears. I'm just looking for a little more bottom end. I dont race the car. Drive it on the interstate most of the time. Thanks for any help>
Old May 25, 2005 | 10:50 PM
Irish Whiskey's Avatar
Irish Whiskey
Yank SS3200-then hold on. 2.3+ str
Old May 25, 2005 | 11:18 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Sort of a trade off.
A higher stall converter will give better performance than gears, but with those 2.73s will cost you some drivability. If you don't mind some looseness then go for it.
Going to say 3.42 gears will improve your performance, albeit not to the extent of a much higher stall, and won't cost you much in terms of drivability. With the stock converter the car won't feel loose.
Since you don't race, I would skip the torque converter entirely. Not worth the drivability issues with 2.73s. I would do gears instead.
Old May 26, 2005 | 10:01 AM
C5magic's Avatar
C5magic
A T/C will definately give you more performance than just a gear swap. Give Yank converters a call and see if you can still get their TT2800 converter. This converter will work nicely with your 2.73 gears because of its very high 3.0 STR. However if you can afford it get the SS3200 with 3.42 gears.
Old May 26, 2005 | 10:35 AM
Mike Mercury's Avatar
Mike Mercury
if you even are considering a TC; do both then
Old May 28, 2005 | 07:15 AM
patmo's Avatar
patmo
I agree with Mike. I did the the 3.42 gears then 6 months later did the t/c vigalante 2800. The most noticeable difference was the t/c. I now lost the dead spots(those areas at which the car bogs down and has to wait till rpms rise to really acelerate) that people with 2.73 gears and stock t/c complain about. You see if you just do one or the other do the gears,because the car will still behave just like stock. I recommend doing both! It is the same labor and with both done your car will drive like stock but have this extra performance mode for when you really want to get on it.
Old May 28, 2005 | 03:25 PM
blktie8's Avatar
blktie8
Old May 28, 2005 | 08:02 PM
BIGMAC's Avatar
BIGMAC
I did the 3.42 gears but not the TC and it was a mistake. I am going back now for the TC.
Old May 28, 2005 | 11:58 PM
JeremyMSG's Avatar
JeremyMSG
If you only have the fund$ right now for one or the other, then wait and save up to do both at the same time
To T/C verses Gear Change
