P0358 Ignition Control #8 Circuit -A
THe car runs and drives fine when I am not into the boost. When I go into boost it starts stumbling and I get the code P0358. I have checked the wiring going to the coils and it is fine. When I test the coil at idle it fires fine. I have also misted the plug wires to see if they are arching out on anything, they aren't.
Could this code be the result of a weak coil? The number 8 coil gets a lot of heat from the turbo so I am not sure if this has destroyed it.
I wanted to see if anyone else has had this problem before I start switching coils around or replacing them.
