Why do I keep blowing this fuse??? It is for the driver-side injectors
It has happened 3 times in 3 months, below are the details:
-Always after the car has set hot (heat soaked not running) for a while... then restarted...
-Replacing the fuse immediately will blow fuse again, I have to unconnect the injectors (driver-side), cycle the ignition and then replace the fuse, for it to NOT blow the fuse...
-It did this once with the factory injectors also...
ANY ideas???
