Need some help with this check engine light problem
Old May 27, 2005 | 09:44 PM
nattblade's Avatar
nattblade
Default Need some help with this check engine light problem
Got on my 1998 pretty good the other day after doing some mods and shortly after that the check engine light came on. Took it to my mechanic and he did a scan and came up with a code PO174 lean Bank #2. Fuel trims both banks 22% adding fuel idle and running. Mods added were Blackwing filter, 1000cfm MAF, Carbon fiber bridge and SLP exhaust. He says the computer was asking for more fuel when I got on it but couldn't deliver. Has anyone had this problem and can you tell me what I need to do. Thank you in advance for your help.
Old May 28, 2005 | 12:29 AM
timf1954's Avatar
timf1954
Put the original MAF back in.
Old May 28, 2005 | 05:29 PM
nattblade's Avatar
nattblade
Isn't there a fuel pressure regulator or something I can change to give it more fuel when it wants it to match the increase amount of air it is getting? Alot of members have changed their MAF's on there vettes. Is putting the original back on the only solution and the MAF is a waste of money?
Old May 28, 2005 | 08:55 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Old May 28, 2005 | 09:15 PM
Jay-rod's Avatar
Jay-rod
These cars on a stock tune hate maf sensors.The stock one works well even on modded cars.
Old May 28, 2005 | 09:23 PM
T_Vert's Avatar
T_Vert
yep put the stock maf in . if that doesnt fix it, pm me ill help you out
Dave
To Need some help with this check engine light problem
