Dang, I love it! The debate goes on.... "Cold Air vs Ram Air". I don't know which is more fun, reading the Thermostat/ Radiator/ Temperature threads or the ones on Intake Air. One thing is for sure, you can't make anything cooler than ambient unless you use some sort of refrigerating device. Be it mechanical or evaporative.
Dang, I love it! The debate goes on.... "Cold Air vs Ram Air". I don't know which is more fun, reading the Thermostat/ Radiator/ Temperature threads or the ones on Intake Air. One thing is for sure, you can't make anything cooler than ambient unless you use some sort of refrigerating device. Be it mechanical or evaporative.: yesnod:
Damn George. That makes two of us. I've been saying you need a refrigerator to get this so called cold air.
Bob, I guess we have to take up where E-T left off. I think he got tired of trying to get the message across, but people (wantabes as he calls 'em) keep the urban myths alive. I love the comment about airscoops reducing the frontal area. If that was the case, why not make the whole front end a big scoop. The only problem would be that it would compress the incoming air and generate heating, but think of the Ram effect you would get.
He implies he's an engineer! Amazing. You've got a good idea there George. One big scoop. Thanks for the chuckle George. Check out the drag section. It's getting almost as bad, I think I may follow in E T's footsteps.
Great info!! It do wonder if you opened up the vents in the front facia if this would have an effect on a stock like setup. I know is won't be as good as a vararam or trap, but I wonder if it could at least reduce the heat soak. Is there any easy way of doing this with the tools you have Dave68?
Its ideal with the "twin-flow" model and yes it does work actually you do not have to compleatly remove the schroud, drilling three eights or half inch holes, as many as you feel is right for your aplication will do some good
I considered doing that but I think cutting the shroud is a better way to go.
Wow! I checked the Drag Race Forum. Some big ego talk there.
If you don't have anything to restrict air flow (i.e. open "ram-air" vent) you don't have anything trying to "push" the air out of the way. Not rocket science, really.
Oh my goodness, one big scoop? Think jet-engine intake. Amazing that they dont put a big front end, and radiator shroud in front of the intake of a jet engine.
I'm glad that you are amused so easily.
You posted "Any time you reduce the effective frontal area of a car, say, by adding air scoops".
Not only amusing, but hilarious.
I don't know squat about jet engines. I do know the front, or intake is much larger at the front. I also know they don't have a radiator. And again, they do have a shroud. Hello, anybody home?
I do have design experience on the 747, 757, 777, F16, F15, F18 and C130 to name a few. And you? You want to dicuss aircraft this isn't the right forum.
Like I said, I'm glad that you are easily amused. Much like my 6 year old.
Same logic as the comedians who suggest we make airplanes out of the same material as the "blackbox" so that they survive crashes.
Real smart. Go get 'em with that....
You posted "Like I said, I'm glad that you are easily amused. Much like my 6 year old. " Let me give you some good advice. Don't ever grow up. You'll enjoy life more.
You are also confused in regards to a black box. A black box is any box containing electronics. They are not designed to survive crashes. The crash boxes are. I'm in the industry, remember?
What are you talking about? Everyone in the United States knows exactly what a "blackbox" refers to in the aftermath of an airplane crash.
I hope I am already all "grown up", 'cause if I add any more height to my 6'8" frame, I'll be hurtin' to ride in my 'vette.
You don't have a clue what Black box means. I tried to tell you but you know better. Keep getitng your education via the news.
Let me try one more time. All boxes containing electronics are black boxes. Design engineers like myself that design this stuff specialize in what's called E/M Packaging. Don't confuse that with a cardboard box.
Black box is a generic term defined by engineers, industry and the miilitary. News people have mis-informed the public to some degree. This is going nowhere and is slightly off subject. If you want more info PM me.
Glad you took my advice and decided to quit growing.
How did this thread get from "cold air intake data" to "black boxes"? Bob, your correct about "black boxes" being a generic term in the Aircraft Industry for any unit containing electronic equipment. I think 2000BSME is refering to Flight Data Recorders which are in that sense black boxes.
As for scoops on aircraft, especially jets, common logic doesn't prevail. That's why the famous NASA scoop was invented, since scoops protruding into the airstream were ineffective. Aerodynamics is a Black Art understood by only a few. For that reason aircraft and auto manufacturers spend big money on wind tunnel testing.
Hi George. Amazing isn't it. That why I told him to PM me if he wants to. Is that you in your younger days standing next to a '53? Great pictures.
I see you have a little aircraft yourself. I've been at this 35 yrs now. If I get back to Lockheed (formerly GD) I'll let you know and we'll get together.
