need help with steering sensor
Old May 29, 2005 | 09:29 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default need help with steering sensor
does anybody know how to set the steering sensor on a1997 corvette? thanks mvvette97
Old May 29, 2005 | 09:40 PM
BAD_TCR's Avatar
BAD_TCR
Yeah. I suppose you mean replace it cause its bad..... take the dash off, disconnect airbag, disconnet steering shaft, pull steering wheel out, replace doughnut steering sensor, put back in carefully in the same position for airbag positioning....
Old May 29, 2005 | 10:49 PM
mvvette97's Avatar
mvvette97
I had the steering shaft off doing a damper change and I think the steering wheel was turned changing the position on the sensor.I am not sure how to align the steering wheel.
Old May 29, 2005 | 11:16 PM
BAD_TCR's Avatar
BAD_TCR
Can't help from there....that was the thing they always told me to be absolutely careful on getting in the same way it came out. Here's a TTT for you, maybe somebody can chim in...
Old May 30, 2005 | 01:10 AM
mvvette97's Avatar
mvvette97
thanks
Old May 30, 2005 | 08:52 AM
Hellobkk's Avatar
Hellobkk
You should be getting a code c1281 and/or c1286 on your DIC as well as "service vehicle soon" found this using the search function:
This is an easy fix (if it's 180* out) if you have a simple volt meter, if so:
With the wheels pointing straight, probe the light blue wire on the INNERMOST position closest to the center of the car, and see what voltage it is showing. (this is under the dash where the steering column enters the engine bay) If it's not showing ~2.4 Volts with the wheels pointing straight ahead then disconnect the steering shaft in the engine bay and rotate the steering wheel one complete turn counter clockwise and take a reading, if it's not 2.4V then rotate the wheel TWO turns counter clockwise and it should read 2.4V if no avail just rotate the steering wheel until you get a reading of 2.4V, reconnect the steering shaft in the engine bay and you're done.
Old May 30, 2005 | 09:33 AM
mvvette97's Avatar
mvvette97
thanks Iwill try that.
Old Jun 3, 2005 | 08:20 PM
mvvette97's Avatar
mvvette97
I tried adjust it and all I could find was .24 volts not 2.4volts.
Old Jun 4, 2005 | 01:03 AM
Hellobkk's Avatar
Hellobkk
Default forum search
Do a search for each of these:
c1281
c1286
"steering sensor"
a lot of info will come up.
Old Jun 4, 2005 | 01:14 AM
mvvette97's Avatar
mvvette97
c1281
c1286
"steering sensor"
I'll give it a try. Thanks man
To need help with steering sensor
