passive key entry
Old May 30, 2005 | 12:40 PM
harley76shovel's Avatar
harley76shovel
Default passive key entry
I purchased a 1998 c-5 a couple of months ago, it did not have a passive key so I purcased one. I can program it where everything locks and unlocks but, it only does it one time. Could anyone please tell me what is happening. thanks
Old May 30, 2005 | 01:22 PM
Birelan's Avatar
Birelan
Just a guess, but since the system never uses the same code twice in a row(to prevent record and playback theft) the two are not staying in sync. Ask the dealer to check the fob they sold you for correct operation.
Old May 30, 2005 | 01:34 PM
tsts's Avatar
tsts
Default Same problem
I've purchased a '99 4 weeks ago and have the same problem. After I re-sync the transmitter and receiver, it works a couple of times right away but then it stops. If I go out of range once, it stops. I've also reprogrammed the FOB, but it still only works once or twice right away then stops. I have already replaced the receiver but that did not cure the problem. I am going to pick up a new FOB and see if that is the problem (yes, I did replace the battery twice on the old one-it didn't help). I'll post to this thread whatever happens.
Thanks,
Old Jun 4, 2005 | 10:41 AM
tsts's Avatar
tsts
Got the new FOB, re-synched, re-programmed it a week ago. All has been well. End of problem. Looks like I did the receiver replacement for nothing, at least it was a used receiver that didn't cost much.
Old Jun 4, 2005 | 11:36 AM
harley76shovel
Default passive key
thanks for the reply, I will go get a new fob and post the results.
To passive key entry
