Lug Bolt cross threaded, what to do?
Old May 30, 2005 | 03:58 PM
boatboatboat's Avatar
boatboatboat
Default Lug Bolt cross threaded, what to do?
I have a lug bolt on an 04 that is messed up. It is NOT the lug nut, as I have tried others on this lug bolt. How big of a deal is it gonna be to fix this? How dangerous to run on 4 good lugs?
Old May 30, 2005 | 04:10 PM
magredZ51's Avatar
magredZ51
I replaced one on the front hub. It's not difficult. Remove
wheel. Remove brake caliper and bracket from knuckle.
Remove rotor. Tap out old stud with hammer. Pull new
stud thru with a stack of washers and a lug nut.
Note: 2 large bolts that hold caliper bracket to knuckle need
to be torqued to 125 ft.lbs and require thread locker.
Old May 30, 2005 | 04:11 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Can you chase the threads?
Old May 30, 2005 | 04:20 PM
boatboatboat
thanx mag red....... I wonder if my dealer will have one in stock? I am leaving for Hilton Head wed AM.
"chase threads"??............. what do you mean? keep turning lug nut and hope it rights it's self?
WOuld it be to dangerous to leave on a road trip with 4 good lugs?
Old May 30, 2005 | 05:12 PM
DsC5's Avatar
DsC5
Except I was able to pound the new one back in with a hammer instead of pulling it through. Note also that the GM service manual calls for replacing the caliper bracket bolts.
Old May 30, 2005 | 05:20 PM
boatboatboat
arrrrrrrrrrggggggg Last time I took a bracket bolt out (to replace rotors) I snapped the bolt off, INSIDE the bracket.
I suck.
To Lug Bolt cross threaded, what to do?
