I just installed my new Hurst shifter, and I absolutely love it. However, as I think back, I am wondering if I installed it right. When I set the forward and backwards set screws (with locking nuts), they really don't seem to do anything. I followed the directions, and because the shifter was up in third gear all the way, it was pretty much making contact with the housing. So, when I backed the screw out 1/4 turn, it really doesn't do anything at all. Was I supposed to pull back on the stick any before I set the screws in place.
Basically, what I have now is a shifter that stops on the housing itself (both forward and backwards), rather than the set screws. Is this a big deal? I wonder if anyone else noticed this, and I'd like to know if others have it set this way. Thanks.
I actually found some posts that say a lot of members don't use them at all, and in fact, remove them. So, please just let me know if anyone out there actually believes the front and back set screws actually serve a purpose on these shifters.
I shift fully into gear (3 and 4) and then turn the set screw until I barely notice the stick move, then I lock it down. This way I know the stick isnt being stopped by the housing and also know it is fully in gear.
Not sure if it helps anything, but logic would suggest it's not hurting anything either.
Not sure what you mean. The shifter is not supposed to touch the stop screws under normal shifting. It should only touch them under very aggressive shifts to help prevent transmission damage. And yes you can still get transmission damage even though the trans has internal stops. Those internal stops can get indented from such hard shifts that over time the shift fork can be bent.
I never had my stop screws installed until I found out what can happen, then I installed them. This just makes for another bit of insurance to protect the transmission. But if you don't shift hard often, then I wouldn't worry about the stops. Hurst has them because it is a performance shifter and they assume you purchased this shifter for aggressive shifts, like in racing. Another reason why it's not a quiet shifter. Noise dampening wasn't the priority.
Basically, I tried to set the screws, but it seems that the shifter was all the way against the housing in both third and fourth. So, the set screw had no effect. I may just be remembering incorrectly. Just for piece of mind, I'll probably tear into again soon. I haven't driven it since this weekend (heavy rain since then), so I'm in no rush. I just don't want to do any damage with the harder shifter. I love the solid throws, but of course I may be being paranoid about the set screws.
I have never brought the car to the track, but I do drive the heck out of it. I was just curious if anyone would suggest I go back in to set the screws correctly.
This shouldn't be the case, the shifter shaft shouldn't be all the way against the housing in third and fourth. I hope you are just remembering it incorrectly. If not then you either have a bad shifter, fake Hurst shifter or linkage issues.
