C5 2003-2004 Fuel Pump Upgrade Harness
May 31, 2005 | 08:44 PM
Please see our new fully PnP 2003-2004 PnP fuel pump upgrade harness shipping June 06/05:
http://www.racetronix.com/RX-C5A-FPWH-2.html
Available from authorized Racetronix dealers.
Racetronix
sales@racetronix.com
C4 Fuel Pump Systems ,
C5 Fuel Pump Systems , High Impedance Injectors >
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Please check our web page for low impedance flow-matched injectors from Siemens and Delphi ranging from 55-95lb/hr.
Jun 2, 2005 | 02:08 AM
Jun 15, 2005 | 05:02 AM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Jun 18, 2005 | 02:07 AM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Jun 18, 2005 | 02:25 PM
How difficult is this harness to install? Does it require the drivetrain and DS fuel tank to be dropped?
Jun 18, 2005 | 03:43 PM
Quote:
The harness is very easy to install and does not require you to drop the fuel tank, exhaust or transaxle.
The only panel that must be removed is the DS rear wheel well cover in order to access the factory FSU connector. The average person should be able to install the harness is an hour or less. There is no cutting or modifications to the vehicle structure required.
http://www.racetronix.com/product/RX.../Dcp_3835c.jpg
Jun 18, 2005 | 03:53 PM
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Jun 19, 2005 | 02:33 PM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Jun 21, 2005 | 10:04 PM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Jul 14, 2005 | 05:17 AM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Aug 4, 2005 | 09:23 AM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Aug 18, 2005 | 04:07 AM
ttt
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Aug 18, 2005 | 11:11 AM
fuel pump harness
Will this work on a 2002 with the higher output walbro pump thet Magnuson uses. Why is it listed for 03-04 only???
Aug 18, 2005 | 12:45 PM
Quote:
The connections on the 03-05 Vettes are different.
The 1997-2002 C5's with the side-loaded fuel module require this harness:
http://www.racetronix.com/RX-C5-FPK-2.html
Aug 18, 2005 | 12:58 PM
Aug 18, 2005 | 05:47 PM
Quote:
Originally Posted by MAJ Z06
Why would we need one?
When your factory fuel pump system can't keep up with your upgrades.
Aug 18, 2005 | 08:26 PM
Cruise-In VI Veteran
Quote:
Yeah I want one anyways for my 99. I plan on the Racetronix kit even though I prolly dont need it for awhile...
Aug 18, 2005 | 08:48 PM
Cruise-In VII Veteran
late 03-05 use different tanks, the pump/sender is at the top of the tank instead of the bottom rear
Aug 18, 2005 | 09:08 PM
Racetronix
60# F/M ,
57# F/M ,
50# F/M ,
42# ,
37# ,
32# ,
28# ,
32# ,
24#
Will this take care of the fuel issues on the 03-04 supercharged cars that want to run 650 rwhp, without spending 2k to switch over to the older systems?
Aug 19, 2005 | 02:17 AM
Quote:
Some customers have made it to that HP level but they have had to upgrade the pump and harness and use a booster. We have a solution for the 03-04 pumps. You must get the pump fitted into your fuel module by Thunder Racing. They have done a number of these already with great success.
