From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Originally Posted by corvette-kid-13
how do I disconect the odometer on a 1999 corvette? It's do to a long trip from coast to coast. Thx for the help in advance
Buy a ticket from Greyhound or Go Hang Yourself Idiot .
The first thing you need do is give your car to someone else so they can watch over it. That will ensure that nobody drives it. If not when you get to your destination just put it on blocks and run it in reverse. Now come on get real
Ill tell you, unplug the plug in the back of the cluster. You wont have any gauges or info though. I backed my car out of the garage and back in just fine without a cluster in it!! I wouldnt go far though even though the cluster isnt keeping track, the black box is. All it takes is for your car to hit a GM scan station and they can tell all..... I can tell you what time your trans,BCM, arrived and departed gm. And a few other things ... Scary isnt it??
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Here is my advise to you you better change your IP address because what you intend to do is A FEDERAL CRIME YOU CRAPHEAD. Im going to have your IP pinged and foward your info on the the Feds YOU *******@%%%$$#%^^%$#@@
I see...one post. Ok, the easiest way is to remove the little plug on the back. If you can't find it, just pull out your Civic owner's manual, and you should find it.
I can't believe I wasted my time on posting to this. I'm just glad we all got a laugh.
What a fine first post. Have you figured it out yet. Look down the left hand side of the Forum where vendors are listed. Someone may sell you a clue. A$$WIPE!
