starting/battery question
Old Jun 1, 2005 | 09:21 AM
abraham's Avatar
abraham
Default starting/battery question
Hey all!!! Its been awhile since I've been at this forum. Anyway I thought I'd post my question before I went out and poked around. My 97 will just click once when trying to start it, then if you go and shake/move the battery(the + wire actually) everything will go back on and the car will start fine. Its been doing this for a while and is getting worse. Everything shuts down. The radio, running lights, etc.. Any help appreciated. Thanks.
Old Jun 1, 2005 | 09:28 AM
2KVetteMan's Avatar
2KVetteMan
How old is the battery?
Are the terminals loose?
Clean the terminals, they are probably dirty. Check the ground wires just incase.
Old Jun 1, 2005 | 09:48 AM
abraham's Avatar
abraham
Its actually the negitave wire not the positive. The battery is an optima about maybe two years old. Doubt its the battery. Terminals are fine. It had a alpine installed years ago and I think it may be related.
Old Jun 1, 2005 | 10:23 AM
abraham's Avatar
abraham
ok so maybe one or both of the terminals were a little loose. Thanks for the replies! Have a good one corvette forumers.
Old Jun 1, 2005 | 11:55 AM
2KVetteMan's Avatar
2KVetteMan
I have an aftermarket stereo system as well. I remember that one of the wires were loose and my voltage was jumping all around, turned out to be a loose connection. CheerS!!
To starting/battery question
