Let car warm up before driving?
Old Jun 2, 2005 | 10:09 AM
Zumin's Avatar
Zumin
Default Let car warm up before driving?
I have a very small commute to work (literally a couple of blocks), should I be waiting for my corvette to warm up before driving over there, or does it not matter that much?
Without waiting for it to warm up the oil in the morning is generally 80-90f degrees by the time I get to work, and in the afternoons 90-100f by the time I get home.
Seems like this might be bad, although the idea of warming my car up for twice as long as the actual trip will take just is striking me as funny also lol.
Old Jun 2, 2005 | 10:11 AM
debmwb's Avatar
debmwb
Could be bad over the long run. Ever thought of a bicycle??
Old Jun 2, 2005 | 10:34 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Doubt it will make any difference. I might say let it warm up if you weren't running synthetic oil, but the viscocity of synthetic oils doesn't change nearly as much as normal oils, thus less reason to let the car warm up. I wouldn't drag race to work with a cold engine..but I wouldn't wait 10 mins for it to warm up either for an easy drive to work...
I pretty regularly just start mine and go with below freezing oil and coolant temps in the winter, but mine only has 166K miles on it, what would I know about longevity
Old Jun 2, 2005 | 10:35 AM
Zumin's Avatar
Zumin
I've actually walked to work a few times, but there's a pretty busy road on the way.
Guess I'll try letting it warm up to 160 or so and see how long that takes, the other side of this though is that I've heard that letting your car sit and run is bad also, although I'm not really sure why that would be.
Old Jun 2, 2005 | 10:38 AM
Zumin's Avatar
Zumin
Hehe, well thats a good vote on not worrying about it. Is the only reason for warming up the car is to get the oil viscosity down?
Old Jun 2, 2005 | 10:46 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Tolerances also change from cold to hot, as I'm sure you know metals expand/contract when heated and cooled. Either way, I might let it warm up until the oil temp got to 100 or so, if it makes you feel better
Old Jun 2, 2005 | 11:08 AM
F1_SS's Avatar
F1_SS
I hardly ever let mine warm up. i usually just start it up and drive to work. I used to only live 3 miles from work (i actually checked, and it only 3 streets to work) but now i live just a tad farther away. I dont race it on the way to work either i just cruise. Its pretty warm here in Dallas so im not to worried about it.
Old Jun 2, 2005 | 11:18 AM
WKMCD's Avatar
WKMCD
Just make sure you get it hot enough a couple of times a week to "cook" off the condensaton that naturally occurs as the exhaust cools.
Old Jun 2, 2005 | 11:43 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
After startup I usually wait until the needle starts to move.
Old Jun 2, 2005 | 01:12 PM
Monster231's Avatar
Monster231
i woudl wait for about 15 seconds for the computer to do its things, and just take it easy on the car. And like it says about, make sure you do get it going a few times a week and open it up
Old Jun 2, 2005 | 01:43 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Coming from MN winter experiences. Don't worry about it, drive it. Don't run the car hard cold. You will need to run the car hard and hot every once and a while, to burn off the water in the system.
Randy
Old Jun 2, 2005 | 01:52 PM
1 Nasty Z's Avatar
1 Nasty Z
Would valve springs be a issue? I know that aftermarket ones should not be reved very high when cold. Would think after time a stock spring would suffer as well.
Just my .02
I always let it warm up a little before driving mine.
Old Jun 2, 2005 | 02:04 PM
davidwp97's Avatar
davidwp97
Good Grief - what a question! It's a Corvette, take the long way to work!
David
Old Jun 2, 2005 | 02:35 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
David
Best answer yet!
Old Jun 2, 2005 | 02:50 PM
cenzo's Avatar
cenzo
Walk!
Old Jun 2, 2005 | 02:51 PM
atz06's Avatar
atz06
I don't warm up the Vette before I drive off. However, I am easy on her until the oil temp hits 200 degree or so.
Old Jun 2, 2005 | 09:58 PM
servohead's Avatar
servohead
I'm with that guy that said "take the long way to work". I have a nice little route that I take in the morning that goes around town instead of the five miles to work. I just leave ten minutes early; you should try it. It really makes for a great start of every day. I mean really, who get's to drive a corvette every day to work? WE DO! So live it up man!
Technically, (I am a mechanic...) you really don't want to just sit there and let it idle to warm it up. You really don't want to start it up cold and go shooting around shifting at 3000 rpm either. Treat your motor the way you want to be treated when you wake up in the morning, take it easy and don't push it. My rules are: Shift 1500-2000 rpm when oil temp is below 150ish. That keeps my oil pressure right around 50 psi. My theory is simply - if you heat the motor up too fast you can cause problems. Head gaskets, consequent oil leaks, who knows.
But, rule number one.... Don't forget to have fun. These cars are built very well and can take a lot of abuse.
To Let car warm up before driving?
Old Jun 2, 2005 | 10:33 PM
Bill Dearborn's Avatar
Bill Dearborn
Even in cold weather the warm up period shouldn't be any longer than it takes to fasten your seat belt after starting the car. Driving the car helps it warm up faster and speeds up vaporation of moisture and acids in the engine.
Bill
Old Jun 2, 2005 | 10:57 PM
azmusclecar's Avatar
azmusclecar
Choices here:
1. Move further away
2. Find a job further away
3. Find a longer way to work
4. Buy a hybrid
5. Start your own business at home
6. Have your boss bring your work to your house
7. Buy an electric car
8. Buy a motorcycle
9. Find someone that needs a ride and go pick them up
10. Put a block heater on
11. Pour hot water on the engine before you get ready to go
12. Move to a house on the top of a hill so you can coast to work
13. Move to Arizona where it 90 degrees when you leave for work
14. Put a solar panel hood on your car to heat the water before you leave in the morning.
15. Cover your car with a thermal blanket at night
Ahhhh come on.............some of these were good...............
Just lightening up the evening chat.
Old Jun 2, 2005 | 11:28 PM
ECV-Tony's Avatar
ECV-Tony
David
....I agree with you Red Racer...best answer!
