Any reprogramming after FAST intake swap?
Old Jun 2, 2005 | 01:11 PM
r1hooligan's Avatar
r1hooligan
Default Any reprogramming after FAST intake swap?
Is the FAST intake and throttle body a direct bolt on? Is it just plug and play? Are there any modicfications to attach to filter? How much horspower can I expect improvement from a stock engine and how much from a heads, cam, headers engine?
Old Jun 3, 2005 | 01:40 AM
SCG620's Avatar
SCG620
im wondering the same thing i have a 2000 vette and i just bought the fast intake. I would of had it on already but im waiting for the coolant crossover pipe from gm since fast doesnt have their version out yet.
Old Jun 3, 2005 | 07:57 AM
Gordy M's Avatar
Gordy M
The FAST system was designed for NO and FI, therefor they are built to leak slightly. When you are making upwards of 550 crank HP, the intake comes into play. As a result, you will need to get a good tune to make the most of the mods. For drag racing, FI or NO mods, a dyno tune is a must, for street driving or track events, a scan tune is best. The dyno tune will max you WOT and acceleration settings and the scan tune will max your accel/decel, mid range, idle, etc settings. Determine what your goals are and get the appropriate tune.
To Any reprogramming after FAST intake swap?
