I have two questions I hope someone could help me with.
1. On a 99, where could I find the starter solenoid?
2. I will be removing the valve covers. Do you need to remove the silver wire reinforced hose that goes over the drivers side valve cover in order to remove the cover? If so, how? Thanks!!!
Solenoid is located on the starter. I have two fuel lines on my 98 and there is enought flexibility to remove the coils and the valve cover, but really not hard to disconnect the fuel line if you so desire.
