How do I remove water spots
Old Jun 3, 2005 | 11:58 PM
jmiller's Avatar
jmiller
Default How do I remove water spots
I had to leave my car in the elements for a couple months, and I've got water spots.
I've clay bar'd, it's smoother but still have water spots. I've got a very very mild polish by 3M and compound foam pad. Hasn't really helped remove the spots.
I know they can etch the paint...
But anyone have any ideas on next steps? Should I try a scratch remover or something like that? It's coming up on Saturday so I'm probably limited to what I can get at Autozone or Pep Boys.
Old Jun 4, 2005 | 12:09 AM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Try posting or searching in the care care section
Old Jun 4, 2005 | 12:10 AM
lost's Avatar
lost
On the same subject, how do you remove water spots from the windows. I have no problem getting them off the finish with mothers cleaner wax, but I've tried everything under the sun and they are still there. They are almost invisable to the naked eye, but I do a lot of in car videos and they show up bigtime.
Old Jun 4, 2005 | 06:07 AM
Joe C's Avatar
Joe C
first of all, go here www.properautocare.com or www.autopia.org both sites have good info...
you might want to try scratch-x first. this should be available at autozone, pepboys, etc.
i would start with mequires #83, their compounding foam pad, and a porter-cable polisher. if that doesn't work, i'd go up to maybe #85. without seeing your finish, it's hard to to give you suggestions -
Old Jun 4, 2005 | 06:09 AM
Joe C's Avatar
Joe C
again -
Old Jun 4, 2005 | 09:37 AM
Rex99Coupe's Avatar
Rex99Coupe
Water spots on glass are usually caused by minerals in water. I have removed them with A-MAZ water stain remover, bought from auto glass shop. Apply with very wet rag and rub in circular motion.
Old Jun 4, 2005 | 04:47 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
RainX makes a window polish designed specifically for this problem. It is so strong it suggest you use it onl;y once or twice a year. Ive used it and it works.
On the water marks on the paint issue:
when a bead of water sits on the upper surface ( hood top and trunk ) these beads act like a magnifying glass and etch into the clear coat. Also acid rain left to sit on a hood roof or trunk can get deep into the clear. Now that the damage is done, the only way to get them out is with wet sanding, done by someone who knows what they are doing. IN the future, good wax protection and a cover would have saved you all this grief.
You thought I was rude and insensitive for posting a large picture of my car.....
Good Luck
Bill aka (ET)
Old Jun 4, 2005 | 05:02 PM
2fast4sanity's Avatar
2fast4sanity
steel wool works great on glass, just don't use it in the inside of tinted windows or rear defroster!
Old Jun 4, 2005 | 07:54 PM
stano's Avatar
stano
Good 'ole vinegar and water has worked well for me used it all the time on my boat!
Good luck!!
Stano
Old Jun 4, 2005 | 09:22 PM
c51998's Avatar
c51998
No Nono I Use To Work At A Car Wash .. Go To Your Local Car Wash And Have Them Spray Acid On It,,, Just Ask Them That.. It Wont Hurt Your Car, They Spray It And Then Rinse With Water Fast,, They Mostly Use The Acid For Tires
Old Jun 5, 2005 | 10:05 AM
Evil-Twin's Avatar
Evil-Twin
HA!
A sure case of the elevator doesn't go to the top floor.
That's about as vague as saying " use a liquid on your windows.."
Vingar is an acid, so is sulfuric, so is muriatic, hydrochloric, so is hydrosulfuric... can I pick anyone?
THanks for the tip !
Old Jun 5, 2005 | 10:09 AM
jrose7004's Avatar
jrose7004
Check this out! www.crspotless.com
Old Jun 5, 2005 | 09:14 PM
jmiller's Avatar
jmiller
That looks cool.
Old Jun 5, 2005 | 09:17 PM
jmiller's Avatar
jmiller
Thanks for all of the help and ideas. Sorry to say I didn't try all of them. I tried a heavier polish from Meguiars. No improvement. I tried clay barring a couple different times. No improvement.
I believe my water spots are now a permanent part of my vette.
I tried. The paint is definitely smoother after my attempts to resolve. I now have 4 coats of zaino, and it looks much better. (at least until you get real close and notice my spots...)
To How do I remove water spots
