anyone use a Fluidamper
LS1/LS6 corvette 10% u/d. im tired of waiting for the asp pushed back till mid july now.price is around $350 but might be comparable in power gain since it actually reduces vibrations and 10% u/d accessories.any feed back?
You should spend the $100 and get the ATI. It's cheap insurance, and an outstanding unit. Don't take a chance, it's not worth it.
ALSO... from the ATI website this info....
"Our dampers are used on performance and endurance engines worldwide. Every Nextel Cup, Busch, and Craftsman Truck engine, and every ASA LSI Vortec engine. GM's Vortec off-road 6 cylinders, the Katech World Challenge C5R Corvettes, and Viper V10 engines. They all use the ATI Super Damper because it has proven to be the most effective damper in the world, thanks to it's versitily and tunabilty."
NOW if a fluiddamper is better... why would each of these race teams be running an ATI super damper?
VR
They only came out with LT1 models a couple of years ago. ATI isn't bad, and with Katech running them it says alot.
I will be trying one soon with a new cam in the Z06. Back to back tests with an ATI would be great, but don't know of any. I can tell you I won't be that test mule. Only plan on dropping the steering once on this install.
When I called their tech line to ask about the need for pinning, the guy said pinning is only mandated when using it in a supercharged application...the blower creates enough extra resistance that slippage is a risk.
I've put 8 road course track event days on mine and I love it...Indy, Memphis, and a bunch of Pocono events plus the drive there and back with no issues at all.
I've been researching as much as I can, because I'm considering replacing the OE damper on my car. Problem is, everywhere you look, everyone has a differing opinion on which unit is "best". I don't like the idea that there's a potential "time bomb" on the front of my engine, but on the other hand, how many LS engined cars/trucks are out there, that haven't had their damper seperate?
And secondly, the idea that NOBODY'S installation instructions say anything about locating the damper in a specific orientation during installation, has me totally confused. For those that have "pinned" their dampers, consider that ATI sells a kit that allows you to randomly drill the crank snout, install a dowel pin, yet where you put the pin, can later inhibit your ability to remove the oil pump/timing gears, should that become necessary.....
And, of course, this is all secondary, to the fact that you have to do some MAJOR disassembly of the car, just to be able to get at the damper in the first place.
There's one of those "mambo themed" songs with the lyric, "The more I see, the less I know". To me, that seems to fit the LS harmonic damper topic.
Don't get me wrong, I think silicone gel is a wonderful thing, when displayed behind a tiny little bikini
. I just don't want it in my damper.GM also rebadges the ATI and sells it in their performance parts line.
Fluidampers are usually heavier than the stock damper.
ATI is generally a little lighter.
The LS damper is neutral balanced, meaning it does not need to be indexed, so the bean counters at GM in their infinite wisdom decided to save some money during manufacturing and not machine the crank or damper with index slots.
I haven't had any trouble with disassembly after pinning. Just a little Emory cloth to knock down any burs and everything slides right off.
It always seems to me that there's lots of people who will tell you Fluidampers are nothing special. I'd think you might as well use a Powerbond and same more money vs using a Fluidamper.
ATI's second drilling fixture actually indexes off the crank key, but in order to use it, you have to pull the water pump, front cover, and oil pump. You then slide the fixture onto the crank snout, engaging the key, then drill away. A better method of locating, but of course, a lot more work.
I'm sort of understanding the "neutral balance" of the damper, so the location isn't critical, but ATI, as well as others, put timing marks on the OD of the damper. If they're there, why not install the unit accurately?
With respect to the Fluidampr VS. Powerbond discussion, I believe that the PB is pretty much an OE damper assembled with better glue. In other words, it's also a 2 piece design, as is the OE part, so it's possible it, too, could come apart. The Fluidampr is a welded together unit, so in a sense, it's a 1 piece unit.
I think OE units have their rubber material physically pressed into the cavity (possibly assisted by adhesives) beween the two rings.
The PBs also use a retainer ring to prevent pulley-walk in case of separation and use steel instead of iron as well.
Excellent value for the money spent.
ok.. best of luck to you in your mod decisions.
