Multimeter Help
Old Jun 6, 2005 | 01:23 AM
vectorz's Avatar
vectorz
Default Multimeter Help
The vert latch on my 98 isn't working... when I hit the vert latch button, it rolls down the windows but it does not pop the hatch.
So I bought a multimeter to see if I can find out if it's an electrical problem at the hatch latch connections.. but I have no idea how to use it. Any tips?
Anyonw know if there is a specific fuse that the hatch latch relies on?
Old Jun 6, 2005 | 04:38 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Get with Bill Curlee ....he can probably tell you more about the electrical stuff than anyone....he is usually around here
Old Jun 6, 2005 | 11:23 AM
QuicksilverBrian's Avatar
QuicksilverBrian
Your going to need to findout which wires are ground and hot. Voltages are either +12v or +5 I think. When you hit the latch button there should be a voltage reading of either going to the latch motor to unlatch the hatch. You put one wire from the voltmeter with the "+" sign on the hot wire and the other wire from the voltmeter "ground" goes to the grond wire. You shouldn't get a volatge reading until you hit the latch switch which will allow current to go through the motor and the voltmeter and the voltmeter should be reading a voltage at this time. If not check your cluster of fuses and one should be marked for the hatch(I am assuming). Check for continuity with your mulimeter on the fuse. This is kinda easy, but if you have not done it then it can be confusing.
Old Jun 6, 2005 | 11:26 AM
QuicksilverBrian
Are your windows supposed to go down when hitting the hatch button? If not then you have a conection hooked up backwards somewhere.
Old Jun 6, 2005 | 01:32 PM
cenzo's Avatar
cenzo
They are supposed to go down.
Old Jun 6, 2005 | 03:27 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
if the windows go down it sounds like the latch solenoid is not working.
I would start there, if you can get to the latch solenoid without removing the latch then unplug it from the solenoid, set the voltmeter to the 20V DC scale (if it has an "autorange" feature then use that) plug the voltmeter leads into the harness plug, if you have a digital voltmeter then polarity doesn't matter, the voltmeter will read in negative numbers, with the voltmeter leads pluged into the harness hit the latch button, you should see a voltage spike everytime you hit the button. if you see the "spike" then the latch solenoid is the problem, if not, your problem is before the button, or possibly a bad button.
Old Jun 6, 2005 | 03:31 PM
vectorz's Avatar
vectorz
Awesome, guys! Thanks, these tips should definitely help.
Old Jun 6, 2005 | 10:20 PM
white90conv's Avatar
white90conv
The button connects to the Body Control Module which in turn unlocks the lid. The hatch circuit has a fuse, #17, in the fuse panel under the passenger seat. You should check that first. There is also a relay that operates the lid solenoid. It is #41, also under the passenger floor. If the windows go down, then the button circuit is ok.
To Multimeter Help
