4L60e Vacuum Modulator Mod..
Old Jun 6, 2005 | 07:39 AM
ben73's Avatar
ben73
Default 4L60e Vacuum Modulator Mod..
Hello,
I am just about to start rebuilding my 4l60e with a street/strip rebuild kit from pro-built www.700r4l60e.com
One of the options he offers is the kit to replace the electronic force motor pressure controller with a vacuum modulator. The benefits are said to be a quicker downshift (no delay), and higher line pressure when making a WOT 2-3 shift. Line pressure would normally be 170-185 psi with the PCM, and 220-235psi with the vacuum modulator installed.
So who has done this, and whats your opinion?
TIA.
Old Jun 6, 2005 | 12:42 PM
Mike04's Avatar
Mike04
Old Jun 6, 2005 | 04:45 PM
fsuforever's Avatar
fsuforever
all FLP transmissions are vacuum modulated & some of the best built a4s in the country i would definatley go with vacuum modulation i would have to tend to think there more reliable than the pcm shifting it
Old Jun 6, 2005 | 05:13 PM
ben73's Avatar
ben73
Well the PCM still controls the shifts, the only task the modulator takes away is the line pressure control.....
Old Jun 8, 2005 | 04:26 AM
ben73's Avatar
ben73
Nobody has a vac. modulator on their 4L60e?
Old Jun 8, 2005 | 08:40 AM
XPC5R's Avatar
XPC5R
Like mentioned above, everyone with an FLP trans, and most other built transmissions go vacuum modulated. You will need to run a hard line back to the transmission for vacuum, but it's worth it.
I have used ProBuilt's vacuum mod. kit and it works great, good consistent shift quality.
Old Jun 8, 2005 | 09:34 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Wow, they have a killer price on a 4l60e road race trans
Old Jun 8, 2005 | 09:48 AM
Boob's Avatar
Boob
I have the Vaccum Modulator in my LT1. It is a definate improvement over stock on the 2-3 shift. I've heard some dog it and others praise it, I however reccomend it.
Old Jun 8, 2005 | 08:40 PM
ron@proautotech's Avatar
0ron@proautotech
Former Vendor
where do you buy the vac mod kit from
Old Jun 10, 2005 | 12:10 PM
fsuforever's Avatar
fsuforever
summit racing sales the kit & i think TCI sales a kit
Old Jun 10, 2005 | 03:29 PM
Boob's Avatar
Boob
Your local transmission supply store should have it. Not your local transmission shop, but the retail supplier. I think the kit runs ~80 bucks. It's a pretty easy install from what I remember. Drill a hole in the tranmission case. Uninstall the force motor and install the vaccume modulator. (don't even need to drop valve body) Run the rubber hose from the vaccum mod to the fitting in the hole you drilled. Run the hose from the outside fitting and into the T fitting that you have intalled in your brake booster hose.
To 4L60e Vacuum Modulator Mod..
