Air Horns
Old Jun 8, 2005 | 06:07 PM
noran01's Avatar
noran01
Default Air Horns
I have a set of air horns and want to put them in the vette do beef up the horn a little
Wiring is no problem but i am wondering where you people mounted the compressor and horns. Pics would be greatly appreciated
Old Jun 8, 2005 | 06:38 PM
Special K's Avatar
Special K
Man, in my opinion you should be shot. Are you serious, putting air horns in a Vette.
If you are serious I hope you have a Hadley setup. That's what I have on the motor home. Mount the horns on the roof and the compressor in the engine compartment.
Old Jun 8, 2005 | 07:26 PM
noran01's Avatar
noran01
haha...no not those kinds...the kinds UNDER the hood! I was going to mount them where the factory ones were but it looks tight.
Old Jun 8, 2005 | 07:36 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
I was thinking of trying the Hella horns there is no compressor and they look like they might fit.
Old Jun 8, 2005 | 07:55 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Cool idea! Where can I get an OOooga OOooga horn??
Old Jun 8, 2005 | 08:26 PM
Special K's Avatar
Special K
Oh, good. I never did like the looks of a Vette with horns on the roof.
Old Jun 8, 2005 | 08:45 PM
curtbriggs's Avatar
curtbriggs
I installed my tri-horns (from Summit) inside the air inlet to the radiator. I bolted the horns and the compressor to an aluminum plate and pop riveted the plate to the plastic duct. I ran the wire from the relay, mounted on the fender panel next to the alternator, up the Hurst shifter lever, through a drilled hole into the shift ****. I made a pressure switch under the shift diagram which is now the air horn button.
I have pictures if you PM me your email. I don't have the status to post photos on the forum.
Old Jun 9, 2005 | 01:29 AM
JETZ's Avatar
JETZ
I want one that plays 'coocaracha'! I call my car 'La Bamba'. ack:
Old Jun 9, 2005 | 10:17 AM
ericdwong's Avatar
ericdwong
No pics now as I'm at work but I have a true air horn setup. The OEM horn freakin sux, and they are the EXACT same horns you can find at Pep Boys. One high one low.
Anyway, here is my setup, I have my airhorns mounted infront of the radiator. They are wired into the steering wheel pad. Fortunately the OEM circuit is strong (has a 20 amp fuse), so it is able to actuate the solenoid of the airhorns. I put a 1/2 gallon compressor tank and the compressor in my right stowage compartment. I didn't have to drill holes anywhere except the radiator shroud and my setup is completely reversible. I'm using polyethelene ice maker line for the airhose. It works great!
Pics later tonite!
Old Jun 9, 2005 | 10:47 AM
curtbriggs's Avatar
curtbriggs
[QUOTE=eRiCdWoNg]No pics now as I'm at work but I have a true air horn setup. The OEM horn freakin sux, and they are the EXACT same horns you can find at Pep Boys. One high one low.
The steering wheel pad SUCKS, unless you drive an A4, try shifting through the gears while passing a slow line of traffic and blow the horn when the typical "Dumb ****" pulls out of the line in front of you. I've got big hands and can't reach the horn section of the pad with my thumb without taking my hand off the wheel.
Old Jun 9, 2005 | 10:55 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I would love to mount a locomotive horn on my car for the Houston idiots. Do you think it would fit under the hood?
Old Jun 9, 2005 | 11:06 AM
ericdwong's Avatar
ericdwong
[QUOTE=curtbriggs]
haha, you must be too lazy to move your hand to hit the horn. I have NO problem at all with engaging my horn. If I'm a passenger and my driver doesnt blow the horn when they need to, I'll reach over and do it for them haha! How about those cars from the mid to early 90's when airbags first started coming out, those damn little horn buttons!
Old Jun 9, 2005 | 11:39 AM
curtbriggs's Avatar
curtbriggs
I had a "DS" pull out in front of me just when I was going for third at around 6 large. Here in TN they're like a line of circus elephants, they just follow the leader, who is usually a Que Tip (gray hair) in a old pick up, going all of 35 in a 55 zone.
That's why I put the air horns switch under the shift diagram. You can't believe how neat it is.
BTW I'm a 1938 model so no malice towards the old. Old is all in your head anyways. Time to go out to the shop and start installing my new AFR 205s.
Cheers, Curt
Old Jun 9, 2005 | 11:54 AM
Cajundude's Avatar
Cajundude
Cheers, Curt
Now that's what I'm talkin' about! I'm gonna be just like you! I've always said it so I better do it.
Old Jun 9, 2005 | 12:09 PM
MY1STPEWTER's Avatar
MY1STPEWTER
An airhorn would for sure get someone's attention next to you. With the low profile of the vette I always try to get by the person I'm passing quickly.
Old Jun 9, 2005 | 01:18 PM
curtbriggs's Avatar
curtbriggs
On one occasion, I had to pass a whole line of "Elephants" led by a "Que Tip", this was a deserted road scenario, started the pass in 2nd gear and I checked the speedo as I eased back into the right lane at around 125. I believe in minimum exposure in the on coming lane. Hope I never have to explain that to the "Judge", don't think he's appreciate this like we do.
Old Jun 9, 2005 | 01:26 PM
jmiller's Avatar
jmiller
get a dixie horn, put 01 on the side, and claim you have a "Dukes of Hazard" car for the new movie.
To Air Horns
