04 Conv display problem
Thanks,
Mark
The vehicle has an erratic display malfunction
which is not always evident. The traction control light will
inadvertently come on the dash and then the message center on the dash
will indicate that every system needs check which then corresponds to
the radio going off. However, it does not happen all the time. If the
ignition is turned off and then back on, the vehicle may be okay,
however in a short period of time the display starts acting up again.
