85 mm Throttle body conversion
Old Jun 9, 2005 | 06:34 PM
Scubanme's Avatar
Scubanme
Default 85 mm Throttle body conversion
Has anybody ever converted an F-body throttle cable operated throttle body to work on a C-5 fly by wire system? I only ask this because there is a really slick throttle body produced by Nitrous Oxide and its a 85mm TB with knifed edge blade and mounted on ball bearings. I think this would be better for modded 346 cu. in. motors instead of the 90mm.
Just a thought?
Old Jun 9, 2005 | 08:52 PM
Scubanme's Avatar
Scubanme
ttt
Old Jun 10, 2005 | 01:22 AM
J-Rod's Avatar
J-Rod
I can't see why it would be beter than a 90MM GM.
We've tested a NW 1st gen, a TPIS, and a GM 90MM. at 503RWHP we only saw 1.5 HP peak HP loss between them...
Old Jun 10, 2005 | 07:53 AM
Scubanme's Avatar
Scubanme
Well, my thoughts were that maybe a 90mm tb might be a bit too much for a small cube motor. I remember quite a few people having issues with programming and getting their engines to run right with the 90mm.
So I was thinking that maybe a 85 would be better for moderately modded 346s.
Old Jun 10, 2005 | 12:25 PM
J-Rod's Avatar
J-Rod
Early issues more related to the designs of the new (at the time) TB's and the ammount of angle on the blade allowing too much air in. The newer TB's which more closely mimic the GM style TB seem to have fixed those issues.
A 90MM TB isn't too big for a 346.
Old Jun 10, 2005 | 06:28 PM
Scubanme's Avatar
Scubanme
J, which TB would you buy?
Thanks for your input
To 85 mm Throttle body conversion
