I ordered a custom ground cam from Lxxxxx and it has "V24D 224/224 112" stamped on the end. I measured the lobes and the lift is correct at 0.580". I ordered 224*/224* duration and a LSA of 112* with +2* advance. I've called and emailed for the complete specs on the cam and can't get the information. I'd like to know the opening and closing numbers without having to put a degree wheel on the engine. Yeah, I know, I should have done it when I put it in and I've got all the tools for degreeing cams but I was running low on Dickle and wanted to hear it run, besides at my age time is of the essence.
Anybody have this cam and did you get all the numbers. I may want to re cam after I install my new AFR 205s and I can't compare cams without the numbers.
Thanks in Advance* Retardedly yours, Curt
